Old 02-14-2014, 09:07 PM   #1
gk
Drives: 2013 Raven FR-S
Need more camber up front
With my current setup I am only running bc racing coilovers as far as front suspension goes. With the camber plates maxed out I can get around -2° tops but looking to get a little more (another degree or so).
I am considering getting some camber bolts to go with it but was wondering if they will function properly with the bc coils. Also my other concern is will the camber bolts hold up under constant heavy load (eg. drifting)? Any feedback is appreciated
gk is offline   Reply With Quote
Old 02-16-2014, 06:13 AM   #2
Ryaquinn
Ryaquinn's Avatar
Drives: FRS
Check how your camber hats are set up. You can flip them for increase if haven't already.
Camber bolts will hold up fine. They have a retaining pin that keeps them from rotating over.
Ryaquinn is offline   Reply With Quote
Front camber adjustment. solidONE Suspension | Chassis | Brakes -- Sponsored by 949 Racing 75 10-01-2015 03:32 AM
*FREE alignment* with Purchase and install of Front Camber / SPL Rear Camber Arms! Corner3garage Southern California 188 04-24-2015 01:10 PM
Negative front camber? Estey Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 01-23-2014 06:33 PM
*FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! Corner3garage Mechanical Maintenance and Tools 6 10-31-2013 03:40 PM
