Old 02-11-2014, 10:30 PM   #1
BuhhDill
Drives: 2014 Scion FR-S
Anyone selling BRZ headlights?
Im looking to get my hands on a set of BRZ headlights.
I love how they look but and know theyll fit in a FRS, But is there anything else i need with them?
BuhhDill is offline   Reply With Quote
Old 02-11-2014, 10:47 PM   #2
MrMarinakos
Drives: Asphalt Monogram Fr-s
The turn signal will be a problem, they have it in the headlight unlike the fr-s and you'll prob have to hook up a harness for that.
MrMarinakos is offline   Reply With Quote
Old 02-12-2014, 12:09 AM   #3
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
can't you try the dealer?
chenshuo is offline   Reply With Quote
Old 02-12-2014, 10:59 PM   #4
soundman98
ProCrastinationConsultant
soundman98's Avatar
good-used headlights really don't go on sale at all.. you're better off getting a brand new set from somewhere..
i've been looking for discounted but still intact brz headlamps for some projects i'm working on for about the last 6 months... all i've found is damaged housings-- which is great to test ideas out on, but not useful for installing on the car..
Old 02-13-2014, 01:44 PM   #5
BuhhDill
you could just bake the headlight and take the lense off, swap it with an undamaged one right?
Old 02-13-2014, 01:45 PM   #6
BuhhDill
I think ill just try to stalk junk yards and wait patiently for them. and if the turn signal is in the headlight there should be a way to just keep it on at all times like the frs running light right?
Old 02-13-2014, 01:47 PM   #7
hanabie
hanabie's Avatar
Drives: WRB LMTD '13
The aftermarket brz headlights are coming out.
hanabie is offline   Reply With Quote
Old 02-13-2014, 10:07 PM   #8
soundman98
soundman98's Avatar
most of the damaged housings i've looked at, the back half of the housing is damaged, usually the mounting tabs are cracked or broken off.. one of my test housings(i have a separately purchased L/R pair) has damage to the plastic shroud pieces that surround the projector and signal.. the other, there is damage to outer perimeter of the lens, as well as most of the mounting tabs.. so out of my test set, the one would hold water better then a bath tub, and the other won't mount to the car
so yes the lens can just bake off, and it is the easiest part to replace, but usually the lens isn't that part that is damaged, so it doesn't really get you anywhere.
link? though i really haven't seen any other headlights i'd want(i've seen the winjet and sonar ones).. the gt86/10 series one's are nice, but i like the led accenting on the brz units much better, as well as the allowance they gave me to fit an extra set of projectors where the current turn signal is..
overall, i'm quite happy with the brz headlights-- it was partly the reason i bought a brz over fr-s actually.. i'm kind of a headlight nut..
Old 02-14-2014, 01:28 PM   #9
hanabie
hanabie's Avatar
link?
I don't know who makes it unfortunately.
Old 02-14-2014, 01:35 PM   #10
Shindig
Drives: 2013 FRS
Spec-D. See thread: http://www.ft86club.com/forums/showthread.php?t=50851
Shindig is offline   Reply With Quote
Selling an AZ car to someone in CA tracerit Southwest 0 10-27-2013 01:39 AM
Feeler: Selling retrofitted blacked-out headlights retrosmiths Exterior Parts (Aero, Lighting, Etc.) 5 07-30-2013 11:19 PM
Trade FRS headlights for BRZ headlights? Teknian_Culprate13 Exterior Parts (Aero, Lighting, Etc.) 10 07-14-2013 09:11 PM
Why are they not selling? roadtrip1098 New England 22 01-08-2013 12:46 AM
Selling my BRZ Epictetus Northwest 4 11-14-2012 08:59 PM
