Old 02-08-2014, 02:55 PM   #1
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
running on base map??
what are the do's and dont's for running boosted on just the basemap? i wanna play once i install it but really do not want to screw up my car
lbroskee is offline   Reply With Quote
Old 02-08-2014, 03:46 PM   #2
JerryMichaels7
Drives: Whiteout FRS
don't?
life's greatest stories usually start with the words, "fuck it!".
JerryMichaels7 is offline   Reply With Quote
Old 02-08-2014, 03:50 PM   #3
lbroskee
lbroskee's Avatar
Originally Posted by JerryMichaels7 View Post
don't?
if i can't drive on the baseman why did the kit come with it and i was told i should def flash it after install?
Old 02-08-2014, 03:57 PM   #4
mrk1
Drives: Sterling BRZ Ltd
I would think this is a question for whoever you bought the kit from. The idea of a base map is to get the car up and running initially before fine tuning, so if your car fits in the parameters the tune was created for you should be ok.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 02-08-2014, 04:02 PM   #5
stugray
Drives: 2013 GBS BRZ Limited
I think you need to be more clear.
Are you talking about the "Base Map" as in: The Stock ECU Maps that came with the car?
If so - NO you cannot run boosted with the stock ECU maps.
Even if the car could compensate for the boost by internally tuning, the MAF calibrations will be off.
And then you state the "baseman(you mean maps) that came with the kit".
If they sent you a "MAP" then it needs to be put on the car.
But you rarely flash "just" maps unless they are specific to your ROM, and then you need to know what you are doing.
So I think you just need to explain better what you are talking about.
Old 02-08-2014, 04:08 PM   #6
lbroskee
lbroskee's Avatar
sorry about that. ya my stupid atuocorrect keeps changing basemap.
i am referring to the turbo kit base map (tune file). Toni told me its a 6PSI ROM for the kit (i can't run more boost without further mods anyways). and i no he incorporates a boost cut into the file so it won't over boost, but what i was asking is with just that initial file that he sent me is it safe to do hard runs like close to redline and racing or should i flash it and then datalog before i push the car?
i hope that makes more sense
Old 02-08-2014, 04:11 PM   #7
mrk1
why not just ask Toni then, he created it so he will know. Generally base maps are conservative for a safety margin.
The Build Thread
Old 02-08-2014, 04:14 PM   #8
lbroskee
lbroskee's Avatar
i trust real world experience more then data and just wanted to get more peoples thoughts on it. i don't trust any aspect of my car to 1 single person that i still don't know all that well, regardless of what other ppl say.
Old 02-08-2014, 04:20 PM   #9
stugray
And to make things more clear:
A "MAP" is a table that exists within the ECU "ROM".
There are hundreds of "MAPs" within your ROM.
When you reflash your ECU you typically reflash the entire ROM, not just a single "MAP".
It is possible to overwrite just individual MAPs, but that uses very specific memory addresses that are specific to your current ROM ID (e.g. ZA1J700C, etc.), and is best left to the ECUFlash 'experts'.
So I believe that the answer is: You need to install the ROM provided with the boost kit.
Then you need to know what base ROM the modified one is based on, then you can log.
What are you using to flash and what are you using to log?
Old 02-08-2014, 04:29 PM   #10
jamesm
the last base map i logged (wasn't from fa20club) had 50+% fueling error and would hardly rev.
wait until he checks the logs and send you an updated map.
Old 02-08-2014, 07:34 PM   #11
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
In your case, a base map is meant to be used initially after the install to provide drivability.
It should be updated soon thereafter by a proper dyno tune. You should have this done as soon as possible.
Some base maps will run pig rich as they're typically intended to run in the interim and not for prolonged use.
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here]
ecko04 is offline   Reply With Quote
Old 02-08-2014, 10:23 PM   #12
JerryMichaels7
What Jamesm said is what I meant by don't. Do what you have to do to log and get the tune revised.
Old 02-08-2014, 10:25 PM   #13
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
Drives: Faster than you
I have no idea whom this might be.
Ironsquid is offline   Reply With Quote
Old 02-10-2014, 03:45 PM   #14
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I have a pretty good idea. A basemap should at a minimum have MAF scaling for the additional flow/possible change in pipe size, fuel injector scaling if injectors were changed, and possibly MAP sensor scaling if you changed yours. I would expect the car to be safe to drive and have a very safe ignition map. I would not drive if you won't have a boost gauge and wideband gauge to verify that your car is running properly.
RPM dip with A/C running BunnyRZed Issues | Warranty | Recalls / TSB 31 10-22-2014 09:56 PM
Anyone running Advan AVS? Wise Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 07-31-2013 10:52 PM
Running low on gas Arctek83 Scion FR-S / Toyota 86 GT86 General Forum 63 04-15-2013 07:35 PM
HID for Daylight Running Zoomryder Cosmetic Modification (Interior/Exterior/Lighting) 3 09-21-2012 06:47 PM
Running 19's SocalBurt Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 09-04-2012 02:45 PM
