Old 02-07-2014, 06:46 PM   #1
jamesm
Screencast: MAF and Speed Density
[ame="http://youtu.be/VS8lZCNzR5U"]http://youtu.be/VS8lZCNzR5U[/ame]
One thing I forgot to mention in the video is that if you're going to use a charge air temperature sensor (or blow-through MAF's internal IAT sensor), you'll want to zero out the temperature comps by putting '100' in for all of the values.
Another thing i just noticed is that if you were NA you could theoretically still use the MAF's internal sensor and not worry about comps, but then who tunes with speed density while n/a? Nobody lol. For people with no IAT whatsoever (which is none of us), you'll need to use the calibration temperature and compensations.
Other than that it's just a basic primer on MAF and speed density, what they are, how they work and what they're each good for. Also provides a very basic overview of the different options with RaceRom and how to get started setting it up.
More in-depth screencasts covering the tuning of both systems will be available soon.
Old 02-07-2014, 10:50 PM   #2
mrk1
Drives: Sterling BRZ Ltd
Yeah Im going to give this a shot
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 02-07-2014, 11:12 PM   #3
AZFA20
Automotive Connoisseur
AZFA20's Avatar
Drives: too many cars
Very generous of you to have taken the time to show some of the basics for individuals to experiment with EcuTek. As EcuTeks portfolio continues to grow of neat things that can be done in some of the advanced mapping features it will be interesting to see what the community comes up with in a year or so now that we have end user access to it.
LSx Powered 86/ASE Master Certified Automotive Technician
AZFA20 is offline   Reply With Quote
Old 02-07-2014, 11:39 PM   #4
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
James i love you, no homo ! thank you so much for this vid. Slowly grasping more and more about tuning
So to raise the maf limit the only way possible is having a larger pipe ?
Old 02-08-2014, 10:51 AM   #5
jamesm
Bigger pipe means it can meter more airflow (more air flow for a given voltage) but also that the air slows down, so it becomes harder to meter at low speed. It's not the slam dunk solution that some would suggest, but it works. I wouldn't go bigger than 3" since any larger would require a reducer into the throttle body.
Old 02-08-2014, 02:40 PM   #6
tg_1981
@jamesm Love it keep giving away the farm!!!
tg_1981 is offline   Reply With Quote
Old 02-08-2014, 03:19 PM   #7
charged86
charged86's Avatar
jamesm for tuning president
MAF (Mass Air Flow) versus Speed Density, Discussion & Debate for ALL DeliciousTuning Software Tuning 40 04-11-2015 12:56 AM
Screencast: flexfuel with racerom jamesm Software Tuning 7 02-05-2014 10:58 PM
Low Density(60 cars max) event at Roebling Feb 1,2 Deep Six Tracking / Autocross / HPDE / Drifting 3 01-19-2014 07:54 AM
Is Speed Density tuning required for under 400HP street driven cars vgi Software Tuning 35 12-03-2013 06:29 PM
Speed Density Possible? mrk1 Engine, Exhaust, Transmission 3 05-01-2013 01:21 AM
