Old 02-04-2014, 02:21 PM   #1
damaster32
Drives: 2014 BRZ Limited
NOVA emissions exhaust question
Hey guys,
I have a question. For emissions testing in NOVA which exhaust setup should I do if I want to pass. One of the CATs as to be visible right?
Option 1: catless headers with Catted frontpipe
Option 2: Catted headers with catless frontpipe
Question is would both setups work for emissions or do both header and frontpipe Cats have to be visible? I'm trying to figure out the exhaust setup I'm trying to buy.
Thanks
damaster32 is offline   Reply With Quote
Old 02-04-2014, 02:31 PM   #2
v1ru5
Drives: BRZ D4S 6MT L Vortech
Option 1 might be safe if you have a tune
v1ru5 is offline   Reply With Quote
Old 02-04-2014, 02:38 PM   #3
sshole
If it's not a visual inspection of the emissions system, you have nothing to worry about as long as your ECU hasn't stored/thrown a code for broken catalytic converter.
If it's a visual inspection, you are breaking federal law and you are going to pound-me-in-the-ass jail.
sshole is offline   Reply With Quote
Old 02-04-2014, 04:13 PM   #4
camelflage
Drives: pinto power
as above, depends on if the inspector wants to do the visual look. i had no cats on my is300 with an o2sim wired in and passed emissions every time. either way, if you throw a code, its no bueno.
camelflage is offline   Reply With Quote
Old 02-04-2014, 04:16 PM   #5
sshole
Just FYI, my info may be outdated since I moved out of NOVA a few years ago. I now live in an area of VA that does not require emissions inspection, so I can run cat-free and VA can't do a damn thing about it.
The police, on the other hand, can send me to jail. Because tampering with emissions devices is still a federal crime.
Old 02-04-2014, 07:13 PM   #6
swift996
swift996's Avatar
The cat on the header is primary cat. It also works with the O2 sensors/ECU. I think option 2 is safer but as long as you have one cat you should be alright. A front pipe is easy to swap too.
Do they read what is coming out of the tail pipe in NOVA?
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 02-05-2014, 06:41 AM   #7
sshole
AFAIK, sniffer tests are only used on OBD-I cars. OBD-II cars (anything manufactured after 1996) will use an ECU readiness check.
FS - (NoVA) OEM Exhaust Parts (Over Pipe, Front Pipe) swift996 Engine, Exhaust, Bolt-Ons 5 05-05-2014 08:03 AM
Question regarding emissions. Fourskim Northwest 7 06-30-2013 04:23 PM
Emissions question with a ecu flash sw20kosh Engine, Exhaust, Transmission 2 04-08-2013 01:11 AM
Custom Exhaust in MD, NOVA, and DC WorldRallyBlueBRZ Mid-Atlantic 13 11-09-2012 12:24 PM
Question about smog checks/emissions showbe Scion FR-S / Toyota 86 GT86 General Forum 3 09-28-2012 12:03 AM
