Old 07-15-2012, 03:17 PM   #1
chadz
chadz's Avatar
Drives: 2013 brz limited
EQ settings
Any audiophiles in here who can help with eq settings. I plan to keep the stock sound system for now and upgrading it is probably last on my list. i want to try to make the most of the stock setup. I searched online and could'nt find anything helpful. Here is how i have mine setup right now. It sounds good to my ears and i find its a good balance to the different types of music i listen to. If anybody wants to try it out and critique it or give me some tips please do. Or if anyone would like to share their eq settings.
chadz is offline   Reply With Quote
Old 07-15-2012, 08:16 PM   #2
Calum
That Guy
Drives: 2013 asphalt FRS MT
oh god...
diymobileaudio.com
the12volt.com
bcae1.com
http://www.diymobileaudio.com/forum/how-articles-provided-our-members/38290-how-make-your-rta-$100-dlls.html
start reading my friend.
I'll say this much, the factory output changes as the volume increases, so whatever EQ settings you dial in, wont matter much as the end result will vary greatly depending on volume anyway. An Audison Bit 10 might be worth investigation if you'd like to keep the factory HU.
Old 07-15-2012, 09:18 PM   #3
K2
First 8600
K2's Avatar
Drives: Gen2 GR86
Do you like it? Does it sound good to you?
That's all that matters.
K2 is offline   Reply With Quote
How to set the Shift Light & Gear Indicator Display Settings EsoBOFH DIY (Do-It-Yourself) Guides 76 04-21-2020 08:42 PM
Scion FR-S: Adjusting the headunit / NAV "hidden menu" settings EsoBOFH DIY (Do-It-Yourself) Guides 17 04-30-2014 10:11 PM
