Old 02-01-2014, 06:20 PM   #1
jflogerzi
jflogerzi's Avatar
Enkie RPF01's 17x7.5 or 17x8. What Tire Sizes
I have finally settled on RPF01's. I wish i could afford 2 sets of rims, but for now, 1 set will have to due. Rather spend the extra $$$ at the track. Thus I want the lightest, strongest wheels. More I look the only clear choice in my budget is RPF01's. At 15-16LBS depending on rim size, they have decent looks, 1 piece cast rims and are from a dependable manufacture. Will either rim choice clear BBK's? I know for sure the 17x9's will, but what about 17x7.5 or 17x8's? FI is not in my future for a few years thus I am looking @ 215 or 225 size tires to keep the car's handling, while gaining more grip, but shedding several pounds of rotational mass per corner. I plan to lower the car only on RCE Yellows to narrow the wheel gap but not to change the current handling characteristics. What do you guys recommend?
Old 02-01-2014, 09:10 PM   #2
Ray_32
Ray_32's Avatar
Drives: '12 Toyota 86 (RED) MT
I believe 225/45/17 rubber would be perfect for you and these wheels should clear the AP 4-pot BBKs. Not sure about Brembo though. Nice wheels and good luck!
Ray_32 is offline   Reply With Quote
Old 02-01-2014, 09:47 PM   #3
jflogerzi
jflogerzi's Avatar
Thank you for the info. I am guessing the 17x8's are worth it to go with a slightly wider tire down the road?
Old 02-02-2014, 01:20 AM   #4
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
the 17x9s don't have as much space for larger callipers as the 17x8s do..
the 17x8 will clear a bigger range of larger callipers.
86•BRZ is offline   Reply With Quote
FS/ 17x7 Enkei RPF01 and 225/45/17 Dunlop DZII SVThis Wheels and Tires 12 11-14-2013 09:20 PM
Need help choosing wheel/tire sizes jonbonazza Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 09-28-2013 08:20 AM
What 18 and 19 in tire sizes will not mess with odometer Frs32907 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 08-07-2013 03:59 PM
17x7.5 or 17x8? yoshiharadesign Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 07-10-2013 04:31 PM
optimal street tire size for RTR on 17x7 hankster Tracking / Autocross / HPDE / Drifting 110 03-21-2013 12:40 AM
