Old 08-07-2013, 01:29 PM   #1
Frs32907
Drives: Asphalt grey, manual Fr-S
What 18 and 19 in tire sizes will not mess with odometer
Im looking to upgrade my wheels what tire sizes will keep the same ratio as the stock so the odpmeter and speedometer remain okay? Im looking at the konig illuisions wheels or the liquidmetal curve wheels?
Thanks for the help
Frs32907 is offline   Reply With Quote
Old 08-07-2013, 01:45 PM   #2
FR-S Matt
Thanks for the help
245/35/18 is balanced for the odometer. Not sure about 19.
Old 08-07-2013, 01:45 PM   #3
OrbitalEllipses
Drives: Attitude
Originally Posted by FR-S Matt View Post
Not sure about 19.
Rubberband size.
The Following 2 Users Say Thank You to OrbitalEllipses For This Useful Post:
Sportsguy83 (08-07-2013), TrogDor the Burninator (08-07-2013)
Old 08-07-2013, 01:54 PM   #4
Frs32907
would 18x8 rim fit that tire?
Old 08-07-2013, 01:55 PM   #5
TrogDor the Burninator's Avatar
Drives: 2013 Hot Lava FR-S 6 MT
I can't imagine that a 19" tire is going to be able to match very well to the stock wheel/tire circumference. As Matt says - a XXX/35/18 is a VERY close match ... I run a 255/35/18 and its almost dead on with the speedometer.
A 19 inch wheel and tire is going to run into an issue with the second number in the XXX/XX/XX equation if you have wide wheels. You would have to have some narrow wheels to run a xxx/35/19 tire ... otherwise you have to look at something like a xxx/30/19 tire which will start to give you ride quality issues in my opinion.
All this being said ... does 3% difference really matter to you? If you know its only 3mph off at 100 mph ... does that really cause a problem?
2013 Scion FR-S Hot Lava 6MT Current Mods: KW V3 Coilovers - Raceseng CasCam Plates - Volk TE37SL Black Edition 18x9 +45 - Dunlop Direzza ZIIs 255/35 - Tomei Expreme Ti 60S - FT86 SpeedFactory UEL Catted Header
TrogDor the Burninator is offline   Reply With Quote
Old 08-07-2013, 02:17 PM   #6
Frs32907
these are the rims im looking at and really like. I shouldn't have an issue with the 245/35/18 with these?
http://www.discounttiredirect.com/di...w=8&vid=022253
Old 08-07-2013, 02:38 PM   #7
The tire circumference would be just a bit larger than stock (on average - tires differ in size) but it is very close.
Are you on stock suspension? You are going with a wider wheel, so you will need to watch out for the wheels or tires being too close to the stock springs/strut and rubbing in the front and back.
Old 08-07-2013, 02:46 PM   #8
Frs32907
I'm staying stock for right now was looking at those rims and tiress that are 245/35/18
Old 08-07-2013, 03:10 PM   #9
I believe those wheels have a +40 offset, so that will help out with the wider wheels rubbing against the stock strut/spring ... but you are going to be near the fender in the front, so you would need to put in some negative camber. I *think* you would be alright, but you may need to invest in some camber bolts for the front if you cant get enough camber from the stock equipment.
This is my opinion ... not scientific fact ...
Old 08-07-2013, 03:59 PM   #10
Frs32907
Actually im gonna go with a 225/40 18 nitto motivo tire how would that work
Does anyone know the led sizes for each light? t00n3wb Cosmetic Modification (Interior/Exterior/Lighting) 3 04-09-2013 11:08 AM
SSR disk sizes fiveoneone Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 12-18-2012 05:17 AM
My FR-S is a mess SocalBurt Issues | Warranty | Recalls / TSB 17 11-21-2012 03:23 PM
Autoweek: Dealers Don't mess this up BRZ commentary Dadhawk BRZ First-Gen (2012+) — General Topics 8 05-10-2012 05:57 PM
