Old 01-31-2014, 02:54 PM   #1
swift996
swift996's Avatar
Installed new radiator, not feeling hot air w/ heat on?
I installed a Mishimoto radiator and put almost two jugs of coolant in the system. I had the heat on to check for leaks. I couldn't find any and could feel the coolant warm up a little and move through the tubes.
I didn't have the car on for more than 5 minutes or so but the setting of Hi felt like cool air. Just curious if I neglected something? Perhaps it takes a bit to circulate? Thanks in advanced.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 01-31-2014, 03:00 PM   #2
SubaSteve
Captain Cocoa
Drives: CBS BRZ MT
Make sure the recirculate button is off.
SubaSteve is offline   Reply With Quote
Old 01-31-2014, 03:05 PM   #3
swift996
swift996's Avatar
I did both ways and couldn't feel any heat. I popped the bleed screw off and gave the hose coming off the water pump a little squeeze and coolant shot out, so it's circulating.
Old 01-31-2014, 03:05 PM   #4
CaptainSlow
CaptainSlow's Avatar
Turn the fan down to 1. The higher the fan, the longer it's going to take to feel warm air. You're taking heat out of the cooling system for the heating system...the more heat you take out the longer it will take to come to temperature. This has been invaluable here in MI, where it takes forever for the car to warm up in the winter. I usually just turn the fan on 0 or 1 until the car gets up to temp, then turn the fan up a few more to get the temp up inside the cabin.
Ultramarine 2013 Scion FR-S 6MT
CaptainSlow is offline   Reply With Quote
The Following User Says Thank You to CaptainSlow For This Useful Post:
Calum (01-31-2014)
Old 01-31-2014, 03:14 PM   #5
swift996
swift996's Avatar
I'm installing my intercooler tomorrow, so I'll have to wait until after to test. Maybe I just didn't let it get warm enough. The gauge showed normal operating temps after about 5mins but it was off a cold start.
Old 01-31-2014, 03:17 PM   #6
CaptainSlow
You can always turn the heat on full and leave the car closed up for 5-10 minutes. You should definitely tell a difference when you check on it. Remember that even when the engine is up to temp, all of the plastic ducting and everything else also has to warm up before the air will truly come out hot...before then all of those surfaces will leech the heat right out of the air before it leaves the vents.
swift996 (01-31-2014)
Old 01-31-2014, 03:19 PM   #7
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Need to run the car more time.
Old 01-31-2014, 03:22 PM   #8
CaptainSlow
Another note on the fan speed...the slower the air is moving in the system, the more time it has to absorb the heat. If you blast air right through, it won't have any time to warm up before it comes out, especially if the rest of the system and the rest of the cabin is still cold.
Old 01-31-2014, 08:23 PM   #9
humfrz
Is the thermostat working properly ..... ??
Old 01-31-2014, 09:07 PM   #10
midnight23
dying bird under the hood
Drives: 2013 SWP Limited BRZ
takes about 5 minutes or longer usually to begin to get hot air for me.
Build Thread
Instagram
Old 01-31-2014, 09:28 PM   #11
FR-S Matt
My heater in my car is flippin insane with the stock radiator. I end up turning it down after about 10 minutes because I'm roasting. I can't wait to go to an aftermarket one, lol. Mainly for the summer.
Old 01-31-2014, 09:35 PM   #12
pche
Guy on internet
Drives: Slowly
Sounds like you got a big air pocket in cooling system. Run it with the radiator cap off, watch the bubble comes up. Fill the over flow tank up, shut the car off after it get hot, the negative pressure would suck the coolant in.
pche is offline   Reply With Quote
The Following User Says Thank You to pche For This Useful Post:
arghx7 (02-01-2014)
Old 02-01-2014, 09:16 AM   #13
jdubz13frs
jdubz13frs's Avatar
Drives: 2013 Scion FR-S 6MT
Totally agree, haven't looked to close at mine to see if there are any bleed valves but you definetly have an air pocket in the heater core. Easiest way is to run it with the radiator cap off as stated above, and if that doesn't work driving the car around about 5 mins (~ 1-2 miles) should usually push stuff around.
jdubz13frs is offline   Reply With Quote
Old 02-01-2014, 09:20 AM   #14
jdubz13frs
jdubz13frs's Avatar
Just looked around on ALLDATA, and here's something I didn't know - our twins have 2 thermostats. Looks like one is the normal engine thermostat, and the other may be for the in-cabin heating system? Anyone know what the second t-stat is for???
Floating feeling DriftEightSix Suspension | Chassis | Brakes -- Sponsored by 949 Racing 67 05-07-2017 10:57 AM
That wonderful feeling.. Missy Off-Topic Lounge [WARNING: NO POLITICS] 25 01-18-2014 10:16 AM
ZetaPerformance 6PC Radiator Hose Kit Installed Lverasky Engine, Exhaust, Transmission 9 04-19-2013 12:04 PM
Like my FR-S, but still like the feeling of my Celica GT-S brieweb Scion FR-S / Toyota 86 GT86 General Forum 12 07-04-2012 05:16 PM
Anyone feeling amped up? NemesisPrime909 Scion FR-S / Toyota 86 GT86 General Forum 36 08-04-2011 07:49 PM
