Old 01-29-2014, 11:07 AM   #1
Walla Walla
Hicas Thread Basher
Drives: Subaru BRZ 13, Hyundai Genesis 15
need advice, 245/45/16 +35 offset...
like title said, i need advice
i have bought 16x8 inch rims, +35 offset, and i'm wondering if 245/45/16 tires will fit with suspension/fender. Or should i need spacer?
consider that my car is lowered with Tanabe GF210, wich is not an agressive drop.
Also, because this tiresize don't seem popular right now, i was looking for 245/50/16. More choice of models, but wheel/tire wont be same size... i think if i remember correctly diameter will be 1 inch more for the whole wheel/tire.
I dont really care about my speedo reading, but i do care about handling...
will this difference be too much? I already have a set of summer wheels with 225/40/18 and it's .5inch more diameter, and i couldn't say there was a huge difference... but maybe a whole inch more will be noticeable...
so... need advice....
Walla Walla is offline   Reply With Quote
Old 01-29-2014, 12:15 PM   #2
Thorpedo
The SquadWhisperer
Drives: '13 Ultramarine FR-S (STX)
All this info is out there, but I'll be the sucker and spoon feed it to you.
Yes, it will fit. Your inward clearance will be almost identical to stock. (13mm further out offset, with a wheel that is 25mm wider)
Handling wise is going to rest more so on tire selection than these size differences. Taller sidewalls will diminish steering feel so perceived handling will be worse, but grip wise they will be very close. 245/50s will be 1" taller like you said, which will look "funny" to most as they will have quite a tall sidewall. I suggest you stick to 245/45s which I see tirerack has the RE-11 which is a pretty good tire. (Ran it last season in AutoX to the overall regional championship)
Why is it you went with 16s?
Thorpedo is offline   Reply With Quote
Old 01-29-2014, 12:35 PM   #3
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
In for pics. Not sure I've seen "regular" stance 16s on this car yet.
Old 01-29-2014, 01:00 PM   #4
Walla Walla
Hicas Thread Basher
I went 16 to get an oldschool look. kind of a trip. these are my current summer wheel
and this is what i will put this summer
The problem with RE-11, is that in canada... it's 280$ + tx each.... and since i already have 3 other sets of rims with new tires, i don't want to spend that much... but maybe i wont have other choice..
i was kind of affraid that with beefy (if I could say beefy) tire like 245 it wouldn't fit, because it already seems pretty near fenders with my 225/40/18 on 18x8 rims that have the same offset...
Old 01-29-2014, 01:16 PM   #5
Thorpedo
The SquadWhisperer
Right out of the fit directory (which you can access too :p) Stop trying to figure it out yourself and look at what has already been done.
17x9 + 38
Old 01-29-2014, 01:40 PM   #6
Walla Walla
Hicas Thread Basher
thanks!
i already went through the wheel directory, but like i said, i was affraid with the bigger sidewall that the tire could be to close!
guss i will just need to grow some balls and order those sucker!
Old 01-29-2014, 02:21 PM   #7
Thorpedo
The SquadWhisperer
Originally Posted by Walla Walla View Post
thanks!
Hahah! Just take a look at what tires are used and compare the overall diameters.
Old 01-29-2014, 03:51 PM   #8
hanabie
hanabie's Avatar
Drives: WRB LMTD '13
1. no spacers needed. wont rub your front perch
2. get 245/45/16
245/50 too tall and will affect your handling.
hanabie is offline   Reply With Quote
Old 01-29-2014, 04:45 PM   #9
Shenks
Drives: 2013 Subaru WRB BRZ Limited Manual
Sorry to hijack thread but I wanted a question answered, I got 18x8 and I was wondering would it be better for handling and looks if I went with 235 40 or 235 45? Thanks!
Shenks is offline   Reply With Quote
Old 01-30-2014, 07:44 AM   #10
Thorpedo
The SquadWhisperer
2. get 245/40/16
He says he wants the old school look (yet with a carbon hood?)
245/40 will be around 1" shorter than stock, and will look goofy.
Old 01-30-2014, 11:27 AM   #11
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
there is a marginal difference between those two. From what I understand, 234/45 will be far easier to find, in a larger selection of brands and types
Old 01-30-2014, 12:37 PM   #12
hanabie
hanabie's Avatar
typo.. was going to write 245/45
Btw, 245/50 is one inch taller. Thus, the car will look goofy too.
Thanks
Old 01-30-2014, 12:57 PM   #13
Pete156
I like to eat!
40 will be closer to original tire height, less gearing and speedo change
Pete156 is offline   Reply With Quote
Old 01-30-2014, 03:45 PM   #14
Walla Walla
Hicas Thread Basher
hehe, photo don't show it correctly, but it is not carbon fiber, it is a brushed metal/black hood vinyl.
if it doesn't fit wit the look, it will go away
offset is everything notFRS Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 24 04-11-2017 02:52 PM
205/55 16. 40 offset. Will they fit? Nourdmrolnmt1 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 12-02-2013 01:31 PM
What offset is legal? What offset provides most benefit? bdohazelnuts Tracking / Autocross / HPDE / Drifting 2 02-08-2013 01:32 PM
Offset for GT vs. GTS giraffee AUSTRALIA 3 07-20-2012 12:30 AM
deep offset jdmboss86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 06-28-2012 10:12 PM
