Old 01-28-2014, 01:22 PM   #1
F1fletch
F1fletch's Avatar
Drives: 13 FR-S AT
Question Ordered Swifts, will I need Camber Bolts?
Hi guys, after I lower (on swifts) and go for an alignment, what can I expect to see in negative camber up front? Will I need new bolts to get it even?
F1fletch is offline   Reply With Quote
Old 01-28-2014, 01:28 PM   #2
wparsons
wparsons's Avatar
What do you mean by "even"?
Do you want it back to zero, or do you want a bit of negative camber? IMO, you'll want a bit of negative to even out tire wear unless you don't drive it hard at all, then you'll be fine with 0*.
If you want 0, you'll likely need camber bolts. I don't think you'll have much negative with just the springs, but you'll definitely be slightly negative.
flickr
Old 01-28-2014, 01:35 PM   #3
F1fletch
F1fletch's Avatar
Drives: 13 FR-S AT
Thanks for the response, let me clarify. I meant even side to side. I def want some more neg camber in front, just not more than 2 degrees. I have heard you get a bit of wiggle room with the stock crash bolts but not much, this is why I was asking about adjustable bolts for the front.
Old 01-28-2014, 02:42 PM   #4
anewprelusion
After installing Swifts, my front camber was -0.3 & -0.7. My alignment guy tried to even them out by adjusting the stock bolts, but couldn't really get much out of them. I had already bought camber bolts, but opted not to use them.
anewprelusion is offline   Reply With Quote
Old 01-28-2014, 02:47 PM   #5
wparsons
wparsons's Avatar
Chances are you won't be able to get them matching without crash or camber bolts (which essentially do the same thing), or slotting the upper hole of the struts.
If you're good with around -0.5 and aren't worried if they aren't the same side to side you'll be fine with the stock bolts, but I would personally grab some camber bolts (or OEM crash bolts) to get things more exact with what you want.
flickr
Old 01-28-2014, 02:58 PM   #6
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
If anything, it should be the static rear camber you should be worried about. The swift springs are only a 1" drop? If so, you should be fine in the rear from everybody i've talked to. I'd definitely get crash bolts for the front though.
hmong337 is offline   Reply With Quote
Old 01-28-2014, 03:06 PM   #7
anewprelusion
My rears were at -1.9 & -2.3. Installed LCA's to even that out.
Old 01-29-2014, 06:51 AM   #8
ScionFR-S
ScionFR-S's Avatar
Drives: Raven Scion FR-S
Can someone post a link to proper camber bolts to get when going for an alignment to give to the mechanic???
"To make it in America you need three things, a smile, a gun, and a plan. If you need to give up one thing, give up the smile. If you need to give something else up, lose the gun. But never, ever, give up your plan."
ScionFR-S is offline   Reply With Quote
Old 01-29-2014, 04:13 PM   #9
F1fletch
F1fletch's Avatar
Drives: 13 FR-S AT
I ordered the 14mm crash bolts from Subaru (they are cheaper than Scion's version). This should work well to even the front. I won't move on anything for the rear unless it is really uneven.
Camber Bolts in Rear DIE1000DEATHS Suspension | Chassis | Brakes -- Sponsored by 949 Racing 34 05-13-2015 10:19 AM
*FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! Corner3garage Mechanical Maintenance and Tools 6 10-31-2013 03:40 PM
H&R Camber Bolts deedz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 09-08-2013 09:00 PM
Question about adjustable LCA's vs Camber Plates vs Camber Bolts djdnz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 03-27-2013 11:38 PM
