Old 01-27-2014, 10:44 PM   #1
FR-S Matt
Whiteline KCA416 or Crash Bolt for slotted upper strut?
I have the RCE Tarmac 0's and I had the Whiteline KCA416 16mm camber bolts before I put the coils on. With the top hole being slotted, will I be able to get more camber out of a 14mm crash bolt or with the 16mm eccentric bolt? My goal is -2 in the front with stock tops. Stock bolt is still in the lower hole with the Whiteline's in the upper.
I read mixed answers on another thread about the slotted upper holes. Just looking to see if anyone can clarify and if -2 is doable with bolts + slotted uppers.
Old 01-28-2014, 05:08 PM   #2
FR-S Matt
Anyone happen to know the answer or is this a trial I'm going to have to figure out with crash bolts myself at an alignment shop?
Old 01-28-2014, 05:42 PM   #3
KKaWing
KKaWing's Avatar
Drives: Nissan Versa
Perhaps this will help...
http://www.ft86club.com/forums/showt...tted+bolt+slip
KKaWing is offline   Reply With Quote
Old 01-28-2014, 06:02 PM   #4
FR-S Matt
Originally Posted by KKaWing View Post
Read that thread. Even some of the vendors are suggesting that the OEM crash bolts will be okay. I want to know if the whiteline camber bolt which is 16MM will yield a little more camber than a crash bolt or if the crash bolt is optimal.
Old 01-28-2014, 08:48 PM   #5
fooddude
Drives: 04 Toyota Tacoma Prerunner Reg Cab
OEM quality = doesn't stretch, doesn't corrode easily and can be safely torqued much more.
fooddude is offline   Reply With Quote
Old 01-28-2014, 09:09 PM   #6
KKaWing
KKaWing's Avatar
Arn't the whitelines "lobed"? To used lobed bolts on slotted struts you'd need inserts for them to stay in place?
Old 01-28-2014, 09:28 PM   #7
mkivsoopra
I have the tarmac 0 with completely stock bolts/stock top hat and am able to get -2.0 degrees of camber out of it. I even provided the whiteline bolts to the alignment shop to install, but they didn't need it. I'm lowered about 1.5 inches.
mkivsoopra is offline   Reply With Quote
The Following 2 Users Say Thank You to mkivsoopra For This Useful Post:
FR-S Matt (01-28-2014), unsurety (07-23-2014)
Old 01-28-2014, 09:31 PM   #8
FR-S Matt
Originally Posted by mkivsoopra View Post
I have the tarmac 0 with completely stock bolts/stock top hat and am able to get -2.0 degrees of camber out of it. I even gave the whiteline bolts to the alignment shop to install, but they didn't need it. I'm lowered about 1.5 inches.
The stock 16mm bolt on top? If that's the case, I'm selling the Whitelines. Not getting any slip with the lobe.
Old 01-28-2014, 09:33 PM   #9
mkivsoopra
Not sure about the size, but it's whatever that was there from the factory.
Old 01-28-2014, 09:37 PM   #10
FR-S Matt
Yeah, stock is 16mm. Might as well get some money for the whitelines! Had them before the slotted struts on the Tarmac 0's. Thanks man. I'm gonna push on that rotor and tighten up the stocks again. -2 should be reachable. I'm lowered about as much as you. Considering removing the helper spring to drop a tad more to close the small gap even more.
Old 01-28-2014, 09:48 PM   #11
mkivsoopra
Hang on to the whitelines until after the alignment is done, just in case. hahah
Old 01-28-2014, 09:53 PM   #12
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
Stock top hats and crash bolts in the upper slot on my Tarmac 2s and I got -2.0 up front
2013 SWP BRZ
Build Thread: http://www.ft86club.com/forums/showthread.php?t=38781
smbstyle is offline   Reply With Quote
The Following User Says Thank You to smbstyle For This Useful Post:
Old 01-28-2014, 11:19 PM   #13
FR-S Matt
I'll order a pair and take them with me. Pretty cheap.
Old 01-29-2014, 12:14 AM   #14
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
@hanabie seems to have had success with eccentric bolts.
Are your crash bolts OEM or aftermarket eccentric/lobed?
I advise against OEM camber bolts in slotted holes. I torqued the 14mm camber bolt to 114 ft-lbs spec and it slipped in the slot to zero/positive camber as evidenced by the slide marks on the strut (ignore the bolt which I readjusted back to negative):
Some people doubt I set it for negative camber in the first place and bolted it in for positive camber from the start. If so, how did those slide marks get there? Then there are people who doubt I bolted it to 114 ft-lbs, but I had to use a breaker bar to untorque the already slipped bolt because it was on so tight. Below, you can compare the mark left by my slipped 14mm camber bolt in the positive position with the mark left by 16mm stock bolt secured in the negative position. Those are "bite marks" from being properly torqued to 114 ft-lbs. Not just one but two, including the mark left by the slipped bolt at 114 ft-lbs.
If my camber bolt slipped because I just hand snugged it the first time (I usually hand snug before I bust out my big ass torque wrench), then you wouldn't be seeing two bite marks. Just one.
Whiteline Camber Bolts (KCA416) Steve Canada Classifieds 11 01-07-2014 11:01 PM
slotted upper strut hole hanabie Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 11-22-2013 11:31 PM
Whiteline Camber bolts question (KCA416) ML Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 04-02-2013 12:25 PM
BRZ crash bolt same as Impreza lower strut bolt? xwd Tracking / Autocross / HPDE / Drifting 0 07-05-2012 01:19 PM
