Old 11-20-2013, 02:19 PM   #1
hanabie
hanabie's Avatar
Drives: WRB LMTD '13
slotted upper strut hole
Sorry newb question. Do I still need camber bolt for my front struts if my my front struts' upper holes are slotted. I did not push in the rotor when tighten my camber bolt. I just could not get any negative camber. All I got were zero and positive.
Thanks
hanabie is offline   Reply With Quote
Old 11-20-2013, 02:29 PM   #2
hanabie
hanabie's Avatar
If I can just push all way back in and lock the factory/stock bolts, what washer should I use to keep the factory bolts from slipping?
If I still have to use the camber bolts, can you give me some inputs how to get negative camber?
Old 11-20-2013, 05:08 PM   #3
simpleisbest
Senior Citizen
Drives: Scion FR-S
You get negative camber by pushing the rotor toward the engine bay and tightening it in position you want. If your struts have slotted upper holes, it will allow you to push the rotor in more. The more you push in, the more negative camber you get. The crash bolts are just smaller bolts, so they let you push the rotor in more (and get more neg. camber).
If you are using the factory bolts/nuts, you shouldn't need any additional hardware. If properly tightened, they shouldn't slip.
simpleisbest is offline   Reply With Quote
The Following User Says Thank You to simpleisbest For This Useful Post:
hanabie (11-20-2013)
Old 11-20-2013, 05:15 PM   #4
hanabie
hanabie's Avatar
does that mean I dont need any camber bolts to get negative camber due to slotted hole from my coilovers?
oh lord, I think I'm returning my camber bolts...
Old 11-20-2013, 05:24 PM   #5
simpleisbest
Senior Citizen
Drives: Scion FR-S
Yup. With the bolts you will get more neg camber, though.
Good luck!
Old 11-22-2013, 01:33 PM   #6
wparsons
wparsons's Avatar
If the struts weren't pre-slotted, there's a chance you slotted them the wrong way if you can't get any negative camber.
flickr
Old 11-22-2013, 10:31 PM   #7
SLICVIC
SLICVIC's Avatar
Drives: 2006 STi
The camber bolt will give you an increase on negative camber, you may not be adjusting it properly. Very tricky at first lol took me a while to figure it out myself, the bolt lobe and specific "camber bolt washer" have to be in a certain position to achieve negative angle. slotting the upper hole will also work, as stated before if tightened properly it shouldnt slip although the teeth on the washer (that came with the camber bolt) do a good job of avoiding any slipping.
You can see the teeth (small spikes) on the washer here. Ive also heard of people buying the washers alone and using with regular strut bolts to prevent slipping.
Heres a really helpful thread on notched/slotted lower coilover mounts for increasing negative camber - http://zilvia.net/f/chat/422487-max-camber.html
Maxed out camber plates will get you around -3 degrees. To achieve more, theres these notches on our knuckles that hit the coilover that will need to be grinded away when using camber bolts - doing this got me to -5 degrees. Notching/slotting the top strut hole, using camber bolts and grinding the knuckle gave me an end result of -9 degrees of camber
Hope this helped you, good luck. any other questions feel free to PM me
SLICVIC is offline   Reply With Quote
EBC dimpled/slotted rotors installed kleung93 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 06-19-2018 03:05 PM
Dimple milled & slotted rotors? zooki Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 10-01-2013 02:53 AM
FT-86 STG2 Brake Kit VS Wilwood 4R Slotted Front jflogerzi Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 06-10-2013 07:33 PM
NEW PRODUCT! COLORED CROSS DRILLED SLOTTED ROTORS! D2BD Motorwerks Brakes, Suspension, Chassis 4 04-19-2013 05:33 PM
DBA 4000 T3 Slotted Rotors for BRZ/FR-S at Redline360 Redline360 Brakes, Suspension, Chassis 0 07-07-2012 12:41 AM
