Drives: Hunk a Junk
Questions about new wheels
1) If i moved up from the stock 17s to 18s, or at least to 17s with summer tires, how much will my speedo be off? It'll also change the gear ratios I assume?
2) Is there a plug and play method to correct the speedo? Motorcycles have a speedo healer unit you can install to correct the speedo after a sprocket change. Is there a similar way to do this with our cars, and how are most people fixing this issue? 3) What about the TPMS? How is this handled for two sets of wheels? I'd like to have both sets equipped with TPMS sensors, if possible. |
#2 | |
Drives: ‘22 BRZ Limited
1. Generally when people go up to 18's they get a tire with a shorter sidewall, which allows the overall diameter to be the same. Which would mean your speedometer would not be off. 2. I don't know. 3. You'd need to get another set of sensors and have them reprogrammed each time, unfortunately. |
#3 | |
Drives: Hunk a Junk
| Couple questions about lowering and getting new wheels | MichaelCampos | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 12-25-2013 06:23 PM |
| noob questions about wheels | chenshuo | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 04-11-2013 02:07 PM |
| E85 Questions... | ScionFrsFan | Engine, Exhaust, Transmission | 25 | 03-12-2013 10:47 AM |
| Wheels, Wheels, Wheels | Island Import Performance | IslandImportPerformance | Wheels and Tires | 4 | 07-31-2012 10:08 PM |
| Pick up my FRS friday... ordering wheels today. Some questions | NickFRS | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 5 | 06-19-2012 10:14 PM |
