Old 01-22-2014, 04:51 PM   #1
disgruntld
Less than pleased...
disgruntld's Avatar
Drives: '13 BRZ Ltd SSM 6MT
Aftermarket rear deck shelf
Looking for replacement rear decks, but so far the only one I've found was Password: JDM's carbon fiber ones ( http://passwordjdm.com/PasswordJDM-D...8647C2559.aspx ) Anybody else make these? I'm planning on moving the third brake light so I'm looking for the ones with the delete.
disgruntld is offline   Reply With Quote
Old 01-23-2014, 06:23 PM   #2
disgruntld
disgruntld's Avatar
Bump?
Old 01-24-2014, 12:34 AM   #3
wrohdejr
Drives: 2013 subaru limited wrb brz
I have the passwordjdm carbon fiber one and it fits like a glove.
Portland 86ers
wrohdejr is offline   Reply With Quote
The Following 3 Users Say Thank You to wrohdejr For This Useful Post:
Chad86 (11-28-2015), disgruntld (01-25-2014), mixtape (05-11-2016)
Old 01-25-2014, 01:26 AM   #4
zohare
zohare's Avatar
Drives: '13 Firestorm Base AT
I've considered doing my own recover of the rear deck. Moving the 3rd BL up to the top of the window, and sealing off that annoying reflection/light leak, and then filling the deck with foam, sanding as desired, and recovering with whatever material is suitable. Half considered putting some speakers back there, which I may still do, since I'm planning on using the QP spots for some small 8" subs. (Have them in, but not powered. too much rattlyness until I have $ and time to completely build a proper box and dynamat.) Just speculating some ideas if you are going to take it out, might as well just recover it and move that PITA light
zohare is offline   Reply With Quote
Old 11-28-2015, 09:07 PM   #5
Chad86
DrivinginDreams...Cloud86
Chad86's Avatar
Drives: Toyota GT86
Question
Absolutely beautiful part! I love how it better integrates the light, rather than the OEM light perch.
Did you get the Optional Clear Coated Finish?
Also wondering if this is pointless if I decide to tint the back window.
Chad86 is offline   Reply With Quote
Old 11-28-2015, 10:25 PM   #6
wrohdejr
If you tint it black it would be kind of pointless, but then again you would know it's there and if you want it get it. Yeah i had it clear coated because i knew it would have direct sunlight on it all the time.
Portland 86ers
The Following User Says Thank You to wrohdejr For This Useful Post:
Chad86 (11-29-2015)
Old 12-22-2015, 02:07 PM   #7
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
Mine was reupholstered by a professional shop. Matching carpet and holes filled in. Looks factory and it was pretty reasonable for price.
Love not having the brake light in the window when I look in the mirror.
Old 12-22-2015, 02:42 PM   #8
MemphisR
Memphis
MemphisR's Avatar
Drives: 1989 MR2 S/C, 2014 Scion FR-S
Pics, or it didn't happen
"It's ok... It's not structural."- Mikey
MemphisR is offline   Reply With Quote
Old 12-22-2015, 02:43 PM   #9
Summerwolf
Panda Trueno
Summerwolf's Avatar
Ok, it didn't happen. lol.
The Following 4 Users Say Thank You to Summerwolf For This Useful Post:
MemphisR (12-23-2015), mixtape (05-11-2016), phanguy (12-22-2015), YamahaR86 (12-23-2015)
Old 12-22-2015, 08:27 PM   #10
phanguy
phanguy's Avatar
Drives: Scion FR-S Ultramarine
i moved my brake light up too and i'm real happy with how it came out. i redid my own deck with some fabric adhesive and a bit of fabric that appears to match the roof liner. Good enough for me!
phanguy is offline   Reply With Quote
Old 12-23-2015, 11:48 AM   #11
MemphisR
Memphis
MemphisR's Avatar
Why you no post pictures?
Old 03-05-2016, 11:16 PM   #12
Chad86
Chad86's Avatar
Drives: Toyota GT86
Exclamation
I received my amazing product from PasswordJDM, but there is a minor dent in the carbon. I have e-mailed them twice with no response and the damage is near impossible to photograph due to the glossy finish. All I want is at least a discount. Should I just forget about it? I'm sure once it is installed I won't even notice it.
Old 03-06-2016, 09:32 AM   #13
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
Being that the rear deck from Password is pretty pricey. I would try and contact them. If it bothers you now it will be better to get a replacement instead of installing the damaged deck. Hopefully the can give you some sort of discount if you decide to keep it.
The Following User Says Thank You to NyC Zn6 For This Useful Post:
Chad86 (03-06-2016)
Old 05-02-2017, 11:38 PM   #14
Chad86
Chad86's Avatar
Drives: Toyota GT86
Any advice on installation? I'm starting my install now.
I have figured out how to remove the OEM shelf from the forums. Do I need to remove the OEM LED bar from the plastic housing and attach manually?
Password:JDM Dry Carbon Fiber Rear Deck Shelf Subaru BRZ / Scion FR-S (Type I/ II) password:jdm Interior Parts (Incl. Lighting) 124 01-28-2015 03:17 PM
WTB: REAR window top Brake Light (just top half with leds) or full rear deck Kayzer Soze Exterior Parts (Aero, Lighting, Etc.) 1 08-31-2013 02:23 PM
eliminate rear deck popping with rear strut bar? chenshuo Issues | Warranty | Recalls / TSB 11 07-03-2013 06:44 PM
Good aftermarket Deck Unit with Navi?? taimysho0 Cosmetic Modification (Interior/Exterior/Lighting) 2 05-17-2013 07:55 AM
P8400 Aftermarket deck HELP NEEDED WITH WIRING iamkyle Electronics | Audio | NAV | Infotainment 1 01-13-2013 03:41 AM
