Old 01-12-2013, 10:45 PM   #1
iamkyle
iamkyle's Avatar
Drives: Firestorm FR-S
P8400 Aftermarket deck HELP NEEDED WITH WIRING
I have a beatsonic wiring harness and the radio antenna thingy
I'm a little embarrassed that I'm having difficulty with the install but when i plug in the head unit I'm only getting sound out of the speakers on the right side of the car. So I'm looking for help getting sound out of all the speakers...
2 purple wires which i believe i don't need.... the instruction booklet says there used in place of the solid green wires if i have a sub of 70W or higher
here's a picture of the layout
focusing on the YELLOW wires. I attached the mute wire which is yellow and black to one of the 2 yellow wires on the beatsonic harness
black ground wire which i attach to the metal of car
blue wires. I attached the blue and white wire to the beatsonic blue cord which i believe is to power the AMP, the second blue one is attached the the antenna.
reverse gear signal purple and white wire. Not sure what to do with this one
Here's the last one which confuses me. the first red connection is strait forward but im not sure if i need to use the second red output.
With the other wires it seemed strait forward i just copied the colours and yes my wiring is sloppy.
thank you.
iamkyle is offline   Reply With Quote
Old 01-13-2013, 03:41 AM   #2
SVXdc
Radio wiring harness guru
SVXdc's Avatar
Drives: 1996 SVX L AWD
You do need the PURPLE (VIOLET) wires. Connect all 8 speaker wires (4 pairs) from the Pioneer AVH-P8400BH harness to the respective colors on the Beat Sonic harness.
If the GRAY and WHITE pairs were connected properly, you should be getting sound from all of the front and door speakers. So you may have a hidden problem with the WHITE wires too.
The Pioneer's mute wire (YELLOW/BLACK) is not needed. You should disconnect it from the YELLOW, and insulate the end of the mute wire.
The BLUE wires are good. Yes, the FR-S and BRZ have a factory amplifier that drives the door speakers. Your wiring has the Pioneer's amp remote turn-on connected to both the car's speaker amp remote control lead and the car's antenna booster amplifier.
The extra branch on the RED wire (as well as on the YELLOW) are not needed. I'm guessing Beat Sonic provided them for other accessories you might want to add later (e.g., radar detector, Pioneer's optional navigation module, etc.).
Reverse gear wire isn't required until you add a rear view camera. The car's signal is on the factory 28-pin harness (which you're currently not using). That harness also has the leads from the factory 3.5mm aux jack. See this post.
Have you added a subwoofer? Pioneer's notes about the VIOLET and GREEN wires are for when you want the head unit to drive a plain (unpowered) subwoofer speaker directly. You would forgo the ability to drive the car's rear speakers.
SVXdc is offline   Reply With Quote
APT-X Car Deck? The future of car audio pastuch Electronics | Audio | NAV | Infotainment 13 05-17-2013 06:45 AM
FRS aftermarket head unit installation - wiring MindtheGap Electronics | Audio | NAV | Infotainment 35 01-14-2013 09:00 PM
do you think the rear deck rattle... pr086 Issues | Warranty | Recalls / TSB 7 08-03-2012 04:35 PM
anyone getting rid of their beSpoke Deck ? rikdrt1 Electronics | Audio | NAV | Infotainment 1 06-13-2012 03:55 PM
Open Deck Block nrclptcnsmniak Engine, Exhaust, Transmission 36 01-27-2012 01:00 PM
