DEF'SIK_J_STATUS
Drives: 2013 FRS - 2005 WRX STI
HELP: WINJET Headlight LED strip INOP
Sup peeps,
Just received my winjet lights from phastek. They look awesome, but there is one problem... LED strip on the driver side doesn't turn on. Passenger side works fine. DRL's on stock headlight work.... Please keep me updated. Thanks much, Mark |
#2 |
Drives: Asphalt Scion Frs 6MT
Is it wired up correctly? I'd double check.
Possible its defective
| The Following User Says Thank You to DarkCard For This Useful Post: | 1SIKFRS (01-19-2014) |
#3 |
DEF'SIK_J_STATUS
I looked at the wires, all are secured and attached.
I put my old headlight on, everything worked. passenger winjet works with all features... hooked up the driver winjet on the passenger side--- led strip still doesn't work |
#4 |
Hella Flush
Drives: 2013 SWP BRZ
Maybe DOA, doesn't surprise me since they are made in China. Have them replaced.
| The Following 3 Users Say Thank You to Ny Brz For This Useful Post: |
#5 |
Drives: 2013 FR-S Whiteout MT
Might want to very lightly tug on each individual wire in the harness. When I got mine the passenger side didn't turn on at all due to one wire not actually being in all the way, but when I was looking at it one wire was in the connector just not in the actual fitting? Idk electrical terms
| The Following User Says Thank You to Kilos6 For This Useful Post: | 1SIKFRS (01-19-2014) |
#6 | |
DEF'SIK_J_STATUS
#7 |
DEF'SIK_J_STATUS
bump
#8 |
King of Kiwi Palace
Drives: Faster than you
yeah when I put mine in, the harness wire I had popped out. Just make sure you have good solid contacts for the wires. Might be worth checking inside the housing to make sure those smaller brown wires are in tact also.
#9 |
First 86 Driver Baby!
Drives: FR-S, Flex
Contact Phastek and see if they'll take care of it?
#10 | |
Drives: 2014 scion FR-S
Hey same problem drivers side drl wont work second set aswell idk if im wiring them wrong . any results |
#11 |
((•||=(86)=||•))
Drives: '13 FR-S Ultramarine 6AT; '13 Yaris
Hi
I'm a little late to this thread party, but my passenger side led strip wasn't working Since I am in Canada and imported them myself from NY I decided it would be too hard to return them for exchange I checked all the connections inside and found the red & black wires were not connected at all - connector was there ok but obviously it was never plugged in I baked it open and connected it now they work fine Drastic measure for sure but I solved it Good luck with your fix/exchange/refunds
Cusco Suspension Braces | Eibach F & R sway bars | aFe/Takeda Intake | GReddy EVO3 | D2 RS Sport Coil-overs | TSW Interlagos | Centric Front Discs | Hawk HP+ (F) / HPS (R) | Goodrich SS brake lines | TSW & OZ Racing wheels | Continental & Hankook tires | JDP CF Front Lip | Rexspeed CF ground-effects kit | APR CF parts | Winjet headlights & fog lights | Valenti Smoked Reverse | TOM's LED taillights | CF interior upgrades | LED upgrades | and much more
| ***Official Winjet HEADLIGHT GROUPBUY - PRICE Matching - NO WAITING SHIPS NOW | 86SPEED | Groupbuys | 559 | 10-27-2016 02:42 PM |
| WINJET Headlight Question | HATED1 | Cosmetic Modification (Interior/Exterior/Lighting) | 5 | 10-12-2015 03:46 AM |
| **PHASTEK** Winjet JDM Replica Headlight and Tail Light Thread | PhastekSport | Exterior Parts - Lighting | 62 | 04-22-2015 04:15 AM |
| ** WINJET TAILLIGHTS - In stock Ships Same Day | 86SPEED | Groupbuys | 42 | 04-11-2014 05:12 AM |
| Winjet Headlight Groupbuy JDM Style - Chrome/Black 10% OFF BLACKFRIDAY SALE! | Vicious LED | Groupbuys | 2 | 11-29-2013 04:05 AM |
