Northern California NorCal
Old 01-16-2014, 12:11 PM   #1
Pwolf
Pwolf's Avatar
Drives: 2013 GBS BRZ Limited
Guage Cluster Lights...
Anyone here change out their gauge cluster LEDs? Been thinking about changing them to blue. Any tips?
Pwolf is offline   Reply With Quote
Old 01-16-2014, 12:20 PM   #2
Diode Dynamics
Diode Dynamics's Avatar
I am fairly certain they are soldered in LEDs. They may be replaceable, but it's not going to be a simple plug and play swap.
Nick C.
John C.
Diode Dynamics
Old 01-16-2014, 12:48 PM   #3
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
There is a DIY on how to change the clock and thermostat bulbs on YouTube, which are soldered it. Ide imagine its the same will all cockpit lights.
Old 01-17-2014, 02:21 AM   #4
SilentAngel
Guest
Posts: n/a
I've thought about doing something similar, don't know if it'd be worth it though. I've been wanting to put red like on the BRZ, the white is just to bright. I've kinda wondered if it would be just a simple swap from the BRZ to the FR-S. Sorry if its a bit off topic.
Old 01-17-2014, 02:30 AM   #5
kALMIGHTY
Drives: TRD Ultramarine '13
Not me, but it has been done by someone already.
Old 01-17-2014, 11:28 AM   #6
Pwolf
Pwolf's Avatar
Yea, found that one. I think I'm going to start with those and work my way to the gauge cluster once I know what i'm getting myself into. I used to do a fair amount of soldering about 12 years ago but haven't done any since so just worried I'm going to ruin the boards.
Old 01-17-2014, 12:12 PM   #7
HapaHaole
Drives: Grocery cart
use a butane with an adjustable temp setting or a mini 12W soldering iron.
HapaHaole is offline   Reply With Quote
The Following User Says Thank You to HapaHaole For This Useful Post:
Pwolf (01-17-2014)
Old 01-17-2014, 01:35 PM   #8
Pwolf
Pwolf's Avatar
Good to know. I was at Fry's last night looking at irons and didn't know if 12w would be too low.
Old 01-18-2014, 08:09 PM   #9
Pwolf
Pwolf's Avatar
Picked up a 12w iron, some solder, wick, sponge, and ordered some LEDs this morning. Going to start with the center console and work my way up to the gauge cluster. I'll keep this thread updated as I make progress.
The Following User Says Thank You to Pwolf For This Useful Post:
ftc~brz (01-18-2014)
Old 01-18-2014, 08:43 PM   #10
HapaHaole
You should post up a DIY on it. remember now not too much heat with these newer PCB.
Old 01-18-2014, 09:18 PM   #11
Pwolf
Pwolf's Avatar
Yea, I'll be taking pictures/video and post a DIY once i'm done.
I am a bit worried about the heat since I haven't done it in a while. I did buy a little practice PCB to practice on before I go for it :P
Old 01-22-2014, 10:48 PM   #12
Pwolf
Pwolf's Avatar
Got some LEDs in yesterday so I decided to try em out after work.
This panel only has 3 LEDs and it's super easy to get to. The whole process took about 30min I think (I took pictures along the way, minus removing panels, I can do that later). They aren't very bright unfortunately. I may have to find brighter ones but good start for now at least :P I'll move to the HVAC next. Not sure when I'll get to that though.
Old 01-26-2014, 07:07 PM   #13
omegared19
omegared19's Avatar
Drives: White 2013 BRZ Limited 6MT
Nick C.
Yes they are. And for a clean job, first is to not go cheap on the LED's. They seem to have a weird hue after being soldered in. Secondly, find someone who's really really good att soldering and have them do the work just to play it safe. And after it's done, post pix for us to drool over.
omegared19 is offline   Reply With Quote
Guage face MemphisR Cosmetic Modification (Interior/Exterior/Lighting) 12 07-22-2014 04:53 PM
FA20Club Signature P3Cars Guage Andy@FA20Club Forced Induction 88 01-13-2014 10:41 AM
Temperature guage / ECU issue jonboy99 BRZ First-Gen (2012+) — General Topics 0 11-12-2013 02:25 PM
BRZ cluster on FRS? Shipwreck Electronics | Audio | NAV | Infotainment 6 03-07-2013 12:09 PM
Prefered tire pressure guage? diirk Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 10-26-2012 04:48 PM
