Old 01-15-2014, 12:42 AM   #1
Mikeez
Engineering Student
Drives: Scion FR-S 2015
Exclamation [2014 FR-S] Top CoilOver MashUp
Delete?
Mikeez is offline   Reply With Quote
Old 01-15-2014, 12:56 AM   #2
DrDuquette
DrDuquette's Avatar
Drives: 2013 Premium White, 2006 TL
Start reading some posts. You might find what you are looking for.
DrDuquette is offline   Reply With Quote
Old 01-15-2014, 01:07 AM   #3
Mikeez
Engineering Student
It's hard, because I searched HSD.. nothing came up and I searched monopro... can you sum it up?
Old 01-15-2014, 01:09 AM   #4
suaveflooder
KW V3 seems to be the favorite coilover on any forum that I am apart of.
suaveflooder is offline   Reply With Quote
Old 01-16-2014, 01:20 PM   #5
JRP
JRP's Avatar
Drives: 2013 Perl White FR-S
Try searching "HSD*". You need more than 3 characters for the search to work. I found this out the hard way when trying to search for "RSE" and "AEM".
Jim
JRP is offline   Reply With Quote
Old 01-16-2014, 01:37 PM   #6
Anomie
Anomie's Avatar
Drives: 2014 BRZ Limited
Quick tip, search on google instead of using the forum search function, it usually gives better results.
For example, just have to type in "HSD site:www.ft86club.com" without the quotes into google.
cheers!
Anomie is offline   Reply With Quote
Old 01-23-2014, 12:48 PM   #7
Mikeez
Engineering Student
Okay, thank you. Would you say why its better than the other =p
Old 01-23-2014, 12:57 PM   #8
suaveflooder
Wish I could, lol. Never run them personally, not notice that on the M3 forums, here, and civic forums, they seem to be the most popular. I've got a couple friends who track their M3's on a regular basis and have never run anything different on all their cars.
Old 01-23-2014, 01:05 PM   #9
CSG David
CSG David's Avatar
Hey guys, again lol rate your best quality coilover and the reason why you will qualify it for the top.
Also, can you guys tell me what you think of the HSD Monopro CoilOver? Thanks!!
Do you have a budget? What driving application will you be subjecting your car towards? What are your goals? What tire/wheel setup are you planning to run on?
Old 01-23-2014, 03:09 PM   #10
Mikeez
Engineering Student
Presently I will be running stock tire, however later on I would like to increase my tire from 17inch to 18 inch for height. For the width I would go from 7" to 8"
or 17"x8" but for now...stock.
I want to lower my car a little and for winter I want to raise it =p
Driving setting hybrid (summer and winter)
Budget 1500$ around
Old 01-23-2014, 04:03 PM   #11
CSG David
CSG David's Avatar
Budget 1500$ around
Going to PM you.
Old 03-28-2014, 04:14 PM   #12
Mikeez
Engineering Student
I changed my mind, I am going for 18" wheel and 8.5" Width
I want coilovers that are less than 1000$
I also want brakes.................. NOTHING IS FOR TRACK, just street performance day/day
Old 03-28-2014, 04:32 PM   #13
was385
Drives: MT WRB BRZ Limited, 2007 911s
What exactly do you mean by brakes and can I ask why? The stock setup should be more than capable for what it sounds like you'll use this for.
was385 is offline   Reply With Quote
Old 03-28-2014, 04:50 PM   #14
mike the snake
KW V1, or ST (same thing but less $$) will get you lowered with a good street setup that's not too stiff, and well balanced. I have the ST's and love them.
Brakes, for performance, get some good pads and change the fluid, maybe some good steel braided brake lines, better rotors, and call it a day.
If you want more bling and racing performance then a BBK will work but for a LOT more $$.
ST coilvers, new better rotors, brake lines, pads, and brake fluid should put you right at around $1500 I think.
Coilover Review: FEAL SUSPENSION 441 coilover kit mr. slim Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 11-28-2019 06:30 AM
2014 86CUP #1 - Streets of Willow Springs - Jan 18, 2014 CSG Mike Tracking / Autocross / HPDE / Drifting 21 01-25-2014 10:58 PM
BRZ vs Porsche 911 Carrera S (Mile high mashup review) daiheadjai BRZ First-Gen (2012+) — General Topics 1 06-04-2013 03:57 PM
Edmunds 2014 Coolest Cars 2014 FR-S Convertible Wizneber Scion FR-S / Toyota 86 GT86 General Forum 21 07-26-2012 08:51 PM
FR-S VS Mustang MASHUP track_warrior BRZ Photos, Videos, Wallpapers, Gallery Forum 23 05-12-2012 12:51 AM
