Old 01-10-2014, 10:39 PM   #1
protpibe
protpibe's Avatar
Wideband mount location
So I was planning on installing my wideband sensor into the AVO downpipe immediately after the turbo in the spot where the secondary o2 sensor goes. The problem is, I just read that the o2 sensor should ideally be mounted 18" from the turbo, which makes that spot not good.
So where are you guys mounting the wideband sensor?
I'm thinking buying a front pipe and just have it a bung welded on where it meets the overpipe, but was wondering if you guys had a better suggestion. I was looking at getting the catted AVO pipe but noticed that the o2 bung is downstream of the cat.
Old 01-11-2014, 05:48 AM   #2
Bl1tzkr1eg
Drives: Toyota 86
I placed mine on the front pipe. Had the bung welded there.
Bl1tzkr1eg is offline   Reply With Quote
Old 01-11-2014, 09:55 PM   #3
protpibe
protpibe's Avatar
Oem front pipe?
Sent from my HTC One using Tapatalk
Old 01-12-2014, 12:22 AM   #4
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
yeah, after the turbo downpipe goes the overpipe then the front pipe which is the one that has the second Cat.
I welded a bung on my overpipe.
Old 01-13-2014, 12:14 PM   #5
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I would mount it before any cats and as far away from the turbo as possible. Mounting it really close to the turbo just limits the life of the sensor.
Wideband Admired Forced Induction 101 02-26-2014 11:50 AM
Innovate LC1 wideband choi0706 Engine, Exhaust, Bolt-Ons 0 08-27-2013 11:29 PM
*Raceseng Tow Hook w/ Go Pro Mount Built In Front/Rear Mount -fteightysix* 86SPEED Exterior Parts - The Rest 2 08-20-2013 01:37 AM
DIY: Making a GoPro camera mount with a GrimmSpeed front plate mount PMok DIY (Do-It-Yourself) Guides 2 06-11-2013 10:58 AM
Innovate Wideband Air/Fuel Ratio LC-1 Wideband Kit **Special Price** Titanmotorsports Audio/Visual, Electronics, Infotainment, NAV 2 09-14-2012 12:42 PM
