CANADA Canada
Old 01-09-2014, 01:36 AM   #1
ShibaYuki
Drives: 2013 WRB Subaru BRZ Sport-tech
Anyone having problems with vibrations?
Hey guys, long time lurker. Just decided to register a few months ago.
My car has been vibrating a lot. It seems like it's struggling. It started today when I was going to work. I haven't driven my car since Sunday, after the snowfall. And sat in the garage for 2 straight days. Then work day comes, and I started the car fine and heated it up for at least 12-15minutes before leaving. But when I got into the highway, and I started going 110-120km/h. The car started to vibrate pretty hard. It seems like I was on a massage chair. After 10 hours of work, I went home and tested it out again. And the same thing happened. My Brz has never done this before until now. I don't want to take it to the dealership yet until I figure it out why it's happening. Since the dealer will prolly just say "The car is supposed to do that" or something like that.
If anyone has any opinion, advice, or if it happened to you. Please let me know.
Thanks. =)
ShibaYuki is offline   Reply With Quote
Old 01-09-2014, 04:17 AM   #2
Wattage
Wattage's Avatar
Drives: scion fr-s MT
snow/ice jammed up in the wheels?
Wattage is offline   Reply With Quote
Old 01-09-2014, 07:19 AM   #3
tanner
Drives: '10 S4/'13 BRZ/'16 GT4/E30 M3
2nd, it's most likely that.
tanner is offline   Reply With Quote
Old 01-09-2014, 09:29 AM   #4
ShibaYuki
Hmm, that could be true actually. How do I go about of getting rid of it or lessen the snow so it'll stop vibrating?
Old 01-09-2014, 09:41 AM   #5
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
crawl underneath your car and see if there is snow buildup on the wheels/axles/whatever
thaw the car and use your weapon of choice to get the ice/snow out of there.
Old 01-09-2014, 09:50 AM   #6
Wattage
Wattage's Avatar
get a stick or something and get the snow/ice out of there.
It shouldn't really be too hard to figure out
During that crazy ice storm a couple weeks ago I used my ice scraper to remove the ice from my wheels - but it was mostly on the outside surface.
Are you on the stock rims or using steelies?
Old 01-09-2014, 10:00 AM   #7
wparsons
wparsons's Avatar
Just run it through a car wash, problem solved.
flickr
The Following 2 Users Say Thank You to wparsons For This Useful Post:
Kazuya (01-09-2014), krayzie (01-10-2014)
Old 01-09-2014, 10:05 AM   #8
ShibaYuki
I like that choose your weapon idea. I'll see today before I go to work how I go about it.
I'm on steelies right now. And from the looks of it, it does look like it has snow/ice jammed up.
Car wash? I never go through a car wash in gas stations. You think it would solve the problem? I usually wash it myself. Haha.
Old 01-09-2014, 10:08 AM   #9
Suberman
Drives: Subaru BRZ Sport Tech Satin White
Others have experienced this. I have on several cars. Find a heated parkade for a couple of hours. I recommend against bashing the ice out for two reasons: it won't work unless you get it all off which is quite hard to do and there's a risk of damaging the wheel paint.
A hand car wash is another solution, just spray the wheels with hot rinse water until the ice is gone. Don't wash the car if you are intending to park outside, the doors and locks may freeze solid. In other words, if you have access to heated parking problem solved. If not then a car wash will provide the hot water you need but don't wash the car itself. After washing the wheels just drive around a bit and heat up the brakes to dry off the brake calipers.
Suberman is offline   Reply With Quote
Old 01-09-2014, 10:22 AM   #10
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
Not necessarily, the wash may not melt all of the ice and snow, as well as if its very cold out when you exit it could just freeze in the wheels again.
I've seen cars parked overnight indoors that still have ice and snow build up in the wheels.
BRZZZZZZZZZZ is offline   Reply With Quote
Old 01-09-2014, 10:28 AM   #11
ShibaYuki
Hmm... I guess a coin op is the best solution. I just have a feeling that the water will just freeze on the wheels again since it's quite cold outside.
Old 01-09-2014, 10:31 AM   #12
Wattage
Wattage's Avatar
Have you changed your oil recently?
Take it to a place to get your oil changed. Casually mention that you noticed a buildup of ice and snow on the wheels, wouldn't it be great if they helped removed that when they have it up on the lift?
Old 01-09-2014, 10:49 AM   #13
ShibaYuki
That's true as well. Maybe they could. I'm still at 2300 km. Changing the oil at 3000 km. So maybe I can do it earlier.
Old 01-09-2014, 10:54 AM   #14
daiheadjai
daiheadjai's Avatar
Drives: 2003 S2000, 2008 Fit
Not sure if this is related - but I have noticed that after parking for awhile (i.e. overnight), when I start it up and drive around, the brakes have some grinding noises (and you can feel some light feedback as if the disc isn't smooth).
It does go away as I drive, so I'm thinking that it's temperature related (maybe overnight ice buildup)?
However I'm parked in an underground condo garage, and temps are above freezing...
daiheadjai is offline   Reply With Quote
Door speaker vibrations? Subaru BRZ Nissanfan Issues | Warranty | Recalls / TSB 13 03-01-2014 03:10 PM
Engine shaking/vibrations at 1700rpm - when in neutral/idle kharn83 Issues | Warranty | Recalls / TSB 9 11-07-2013 10:00 PM
Rattles & Vibrations brian_c_m AFRICA 65 03-22-2013 03:07 PM
No CEL problems here BRZranger Issues | Warranty | Recalls / TSB 41 12-08-2012 01:36 PM
steering wheel vibrations fiveoneoh Scion FR-S / Toyota 86 GT86 General Forum 17 09-08-2012 05:29 PM
