Old 08-31-2013, 12:39 PM   #1
vtmike
vtmike's Avatar
Drives: Scion FR-S
U0115 OBD trouble code
I had this code pop up on me today while trying to use the torque app to show to a friend. The description is "lost communication with instrument panel cluster control module"
The car was just sitting idling when I noticed the engine light and also the traction control light was on. Everything seems to be running normal.
Has anyone had this code happen?
Sent from my Nexus 7 using Tapatalk 4
vtmike is offline   Reply With Quote
Old 08-31-2013, 12:54 PM   #2
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Maybe its the issue that people have had with the OBD2 connectors not being pinned correctly? That causes alot of problems and headaches with people especially when using ecutek tunes.
Old 08-31-2013, 12:59 PM   #3
Area86
Area86's Avatar
Drives: 2013 BRZ limited SWP
Not that specific code but I got a U0073 (I think that's what it was) while using the torque app when I shut the car off and restarted it right away with the app still running. Sure its something similar with loss of communication with the ecu. Just clear the code and your good to go.
Sent from my DROID RAZR using Tapatalk 2
Area86 is offline   Reply With Quote
Old 08-31-2013, 01:17 PM   #4
vtmike
vtmike's Avatar
Drives: Scion FR-S
Thanks was wondering if it was something to do with torque. Haven't used it in a while and it happened while I was using it so I suspected that was the culprit.
Sent from my SCH-I535 using Tapatalk 4
Old 08-31-2013, 01:24 PM   #5
448hpsti
In Test:Oil Fed SC
448hpsti's Avatar
Drives: Vortech Prototype Test Car
It's nothing
Often software looks for modules in car that don't exist, I get similar stuff on ecutek
I wouldn't worry about it
448hpsti is offline   Reply With Quote
Trouble With Lights jpit Cosmetic Modification (Interior/Exterior/Lighting) 7 06-24-2013 09:51 PM
Perrin oil cooler trouble ft86me Engine, Exhaust, Transmission 9 04-29-2013 07:56 PM
Trouble installing TRD Air Filter?? Mako Engine, Exhaust, Transmission 1 04-16-2013 11:53 PM
Trouble Accessing Phonebook bneale Electronics | Audio | NAV | Infotainment 11 07-13-2012 10:32 AM
trouble shooting tim saylor Other Vehicles & General Automotive Discussions 0 07-01-2012 01:04 PM
