Old 01-01-2014, 11:02 PM   #1
Fat Spider
Fat Spider's Avatar
Drives: red 86 GTS man / R33 GTR VSpec
65mm overpipe
Has anyone got any first hand experience of performance gains made by fitting a 65mm [2.5"] overpipe with no other modifications. Thanks in advance
Fat Spider is offline   Reply With Quote
Old 01-01-2014, 11:12 PM   #2
humfrz
What is the size of the OEM overpipe down there .. ??
humfrz
Old 01-01-2014, 11:20 PM   #3
Fat Spider
Fat Spider's Avatar
humfrz
The standard overpipe is smaller than 65mm but has areas that are squashed to give clearance which restricts the flow I would think dramatically.
The Following User Says Thank You to Fat Spider For This Useful Post:
humfrz (01-02-2014)
Old 01-01-2014, 11:29 PM   #4
DriftEightSix
Pegasus White
DriftEightSix's Avatar
Drives: 86
There are heaps that make 21/2" overpipes.
Perrin, JDL, Nameless, Motvi + more.
Driving: Pegasus White Manual GTS 86.
DriftEightSix is offline   Reply With Quote
Old 01-01-2014, 11:53 PM   #5
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
I recently fitted 63mm overpipe for the Sprintex SC with already having Borla header and full decat exhaust, I can't honestly say the overpipe made any difference, even on dyno I recorded same KW prior to fitting overpipe.
Ryan86 is offline   Reply With Quote
Old 01-02-2014, 12:17 AM   #6
Fat Spider
Fat Spider's Avatar
Ryan86 am I understanding you correctly, you already had full decat system, borla header and sprintex fitted and dynoed then fitted a 63mm overpipe and re-dynoed with no improvement in figures.
If this is the case, it is exactly the info I was after, thanks.
Old 01-02-2014, 08:31 AM   #7
Ryan86
Road Warrior
Ryan86's Avatar
You understanding me correctly.
Before fitment of overpipe dyno and after fitment dyno showed no improvement.
The only significant change in power while still NA, was DIF, Borla header with a tune, got me 18wkw gain.
Not sure if anyone else found changing the overpipe increased power?
Old 01-02-2014, 09:08 AM   #8
wparsons
wparsons's Avatar
The overpipe isn't as much of a restriction as the front pipe, if you're only going to replace one part replace the front pipe.
flickr
OEM Overpipe Philly758 Want-To-Buy Requests 2 09-04-2013 08:45 AM
Motiv Concepts Overpipe + HFC, Overpipe + Test Pipe Specials! MotivConcepts Engine, Exhaust, Bolt-Ons 96 07-19-2013 02:03 AM
WTB overpipe jamesm Engine, Exhaust, Bolt-Ons 0 06-30-2013 08:01 PM
wtb overpipe hunter3232792 Engine, Exhaust, Bolt-Ons 7 05-12-2013 01:38 AM
overpipe? ft86me Engine, Exhaust, Transmission 19 03-28-2013 09:57 AM
