Boosted
Drives: Not a supra....yet
stock arms, and strusts bolts
Greetings
As I upgraded my LCA's and put my coils on I misplaced a few bolts from the stock lca, and a bolt or two from the strut. I looked @ online part websites and didn't seem to find the 3 LCA bolts to go back to stock, and for the strut I saw two different bolts, but I remember fronts and rear were identical. It's going to be helpful if somebody could help me find the part numbers for the bolts, or maybe I could use the bolts provided on the stance lca's? Thanks |
Drives: Scion FRS
See if this link helps.
http://wardmuscatellsubaruparts.com/...&siteid=216475 |
Senior Addict
Drives: 86 GT
LCA-hub bolt: SU00302781 (nut: SU00302870)
LCA-shock colt: SU00303803 (nut: SU00302870) LCA-endlink bolt: SU00302804 (nut: SU00302883) Strut upper bolt: SU00302805 Strut lower bolt: SU00302818 Nuts for upper & lower: SU00302889 |
#4 | |
Boosted
| rear camber adjuster bolts or lower control arms? | mike the snake | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 25 | 06-30-2015 08:34 AM |
| *FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! | Corner3garage | Mechanical Maintenance and Tools | 6 | 10-31-2013 03:40 PM |
| rear camber adjuster bolts or lower control arms needed? | Raven23 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 22 | 10-31-2013 01:30 AM |
| Front stock struts/bolts max camber Q.. | OICU812 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 10-15-2013 04:45 PM |
| Tein S-Tech, Stock Wheels, Camber Bolts, Alignment. Yes, I've used search already. | Shiro86 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 08-14-2013 09:44 AM |
