Old 12-19-2013, 02:34 PM   #1
amram
amram's Avatar
Drives: 2013 FR-S AT
Getting new 16" wheels with winters, do I need to do wheel alignment?
Hi All, noob question. First RWD car and first 2nd set of wheels/tires.
I am getting a new 'winter tire and wheel package' from tirerack. Called the local tirerack recommended installer about doing the swap ($9 ea) and he said they recommend also getting wheel alignment ($90) done when doing the wheel swap. I'm trying to keep costs down, do I really need to get the wheel alignment done at the same time? Car is only 6 months old and 6000mi.
In case it matters, the wheel I am getting is -
MSW type 14 16" ($89) Size: 16x7, Offset: 38mm (I would have gone steelies but they are sold out)
http://www.tirerack.com/wheels/Wheel...&association=1
And the tire I have not decided yet (either the Altimax or Pirelli Winter Carving Edge or the Sottozero)
"That's why I like the GT86 so much..... It's a car designed for one thing only: fun." - Jeremy Clarkson
amram is offline   Reply With Quote
Old 12-19-2013, 02:37 PM   #2
Kevstra
Kevstra's Avatar
Drives: 2013 Subaru BRZ Sport-tech 6MT
I've swapped wheels many times without an alignment with no problems. If you're just swapping the wheel and the outer diameter is the same, suspension geometry shouldn't be affected.
Also, why are you driving out and paying someone to change your wheels? It's pretty easy... My baby sister does it herself.
Veronica, the 2013 WRB Subaru BRZ Limited
Kevstra is offline   Reply With Quote
The Following User Says Thank You to Kevstra For This Useful Post:
amram (12-19-2013)
Old 12-19-2013, 02:53 PM   #3
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Only time you need alignment is when lowering or raising or changing actual suspension components. Or when you really hit something hard and put stuff outta whack. Also as said ya do it yourself a ten minute job easy peazy cover girl ...
The Following User Says Thank You to OICU812 For This Useful Post:
amram (12-19-2013)
Old 12-19-2013, 02:57 PM   #4
amram
amram's Avatar
Yes, (from what I have read here on other threads) the 205/55R16 tires that I am getting are supposed to be almost the same outer diameter as the stock 215/45R17
About doing it myself LOL, I guess because I don't have the tools that (I think) I need (torque wrench, jack stands).... maybe I should buy them....
Old 12-19-2013, 03:10 PM   #5
Steve
Steve's Avatar
Drives: 6MT
no alignment needed
breaker bar, jack, torque wrench
will cost you maybe the price of two wheel swaps from a shop, not to mention the gas and time you save
Steve is offline   Reply With Quote
The Following User Says Thank You to Steve For This Useful Post:
amram (12-19-2013)
Old 12-19-2013, 03:13 PM   #6
fourvalleys
Howdy!
fourvalleys's Avatar
Drives: Party ST, Classic Mini
You don't need an alignment. The change in circumference is very very small. I like this wheel and tire size calculator a lot. The wheel size (width/offset) doesn't matter, but the tire size does. Here's a comparison of the setup you mentioned:
e: this is the exact setup you're looking at. Stock is on the left and the new ones are on the right. The stuff marked in red at the bottom is what's important for this question. Diameter or circumference. Bigger/smaller wheels will change the geometry of the suspension components, which cause the wheel to sit at a different angle. If they're close, you aren't going to gain much from an alignment.
PS - do it yourself! Like someone up above said, buy the tools. Alternately, buy a case of beer and ask a buddy. Don't be embarrassed about asking. If someone came to me with a 12 pack and said "I need help putting on my winter wheels but I didn't want to pay a shop 40 bucks" I'd be more than happy to help them.
fourvalleys is offline   Reply With Quote
The Following User Says Thank You to fourvalleys For This Useful Post:
amram (12-19-2013)
Old 12-19-2013, 04:00 PM   #7
amram
amram's Avatar
Great info, thanks for the posts everyone, appreciate it. I think I will get the tools and try this myself.
Old 12-19-2013, 04:19 PM   #8
Kevstra
Kevstra's Avatar
That's the spirit!!! You gotta start somewhere.
Soon you'll be engine-swapping like a pro.
Old 12-19-2013, 06:27 PM   #9
amram
amram's Avatar
Tires and Wheels ordered! I went with the Altimax. Tools ordered! Here I go! LOL
Old 12-21-2013, 05:21 PM   #10
Steve
Steve's Avatar
Drives: 6MT
Nice, watch some DIY wheel change videos on youtube and you are good to go. Torque the bolts on to 89ft-lb
Old 12-21-2013, 07:26 PM   #11
wparsons
wparsons's Avatar
Just to clarify, even if the diameter was different you still wouldn't need an alignment. Wheels/tires are not part of the alignment, the only time you would need an alignment when swapping wheels is if the offset/width is different and you're adjusting the alignment to avoid rubbing (which isn't the case here at all).
flickr
The Following User Says Thank You to wparsons For This Useful Post:
amram (12-22-2013)
Old 12-21-2013, 07:31 PM   #12
utekineir
blowhard
Drives: frs, project forester
if you were closer i'd do it for a handie
assuming your hands are soft, which i'm pretty sure they are
utekineir is offline   Reply With Quote
Old 12-22-2013, 08:28 AM   #13
amram
amram's Avatar
Lol. Well that's the internet for you. Thanks but I have the tools on the way. Hahahahaha
Old 12-23-2013, 01:17 PM   #14
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
When you get the wheels on, post up a new topic in this area with specs and photos so I can add them to the Wheel Directory! Thanks.
Wheel "holds air", how safe are damaged wheels? #87 Other Vehicles & General Automotive Discussions 2 06-20-2013 10:48 PM
wheel alignment needed? j2digit Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 06-10-2013 05:32 PM
TSW Wheels 17" 18" Nurburing + Interlagos and More (Wheel+Tire Package Available) MIKE@MRTIRESOLUTIONS Wheels and Tires 0 12-20-2012 05:12 PM
RTR Wheel Alignment simpleisbest Tracking / Autocross / HPDE / Drifting 61 11-07-2012 07:48 PM
