Old 12-18-2013, 11:50 AM   #1
jarviz
jarviz's Avatar
Drives: Raven FRS MT
TPMS
So I hit pothole yesterday and caught a flat and obviously the Low Tire Pressure light comes on. I replaced the flat with the spare and the light is still there.
So that led to wonder is the light still on because the flat tire is sitting in my trunk and it's still sending the signal the car... or is possible I have another tire with low pressure. I know I could easily figure this out by checking the pressure on the other tires haha
jarviz is offline   Reply With Quote
Old 12-18-2013, 01:40 PM   #2
Eurasianman
Chief
Eurasianman's Avatar
Drives: 2013 DGM BRZ Premium 6MT
I would assume it is still on because you have the flat tire in your trunk. Should go away once you have the flat repaired. It looks like it takes about a minute to update. Works better if the vehicle is moving. Hope this helps.
Eurasianman is offline   Reply With Quote
Old 12-18-2013, 01:57 PM   #3
wparsons
wparsons's Avatar
If you're missing a sensor, or have a sensor sending a lower pressure than the ECU wants then the light will be on.
flickr
Old 12-18-2013, 03:13 PM   #4
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Yes.... and no.
My TPMS light comes on at random times, and my stock wheels are sitting in the garage on a rack.
My aftermarket wheels do not have TPMS on them, and more than half the light is off and everything is "normal".
Frankly, just ignore the light. It's useless.
-alex
NEED HELP!! TPMS light on. with TPMS installed on aftermarket rims+tires Figo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 09-23-2013 08:11 AM
TPMS on and off? dem00n Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 11-06-2012 09:56 PM
Changed to new wheels w/o TPMS, car still thinks I have TPMS sensors? Ahz Issues | Warranty | Recalls / TSB 9 11-06-2012 08:25 AM
TPMS? 636 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 10-22-2012 10:57 AM
so what is everyone doing about their tpms? Hachi6 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 07-22-2012 05:04 AM
