Old 11-06-2012, 06:16 PM   #1
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
TPMS on and off?
I had the TPMS light on early this morning, check all the tires and pressure, nothing was wrong. Later on the way home it turned off after i did a turn, the hell?
Has this happened to anyone else? I did a quick search, nothing came up.
I did have the front driver side TPMS replaced around a month since Toyota said it was "broken".
Is it PMSing?
Old 11-06-2012, 07:16 PM   #2
Blypr
Drives: 2013 Asphalt Scion FR-S
They're pretty temperamental when it starts to get cold.
Blypr is offline   Reply With Quote
Old 11-06-2012, 07:52 PM   #3
JDMenrique
DEEEERP
JDMenrique's Avatar
The exact same thing happened to me today. This morning I turn on the car and the light is on, all 4 tires seem to be fine though I have not checked the pressure
JDMenrique is offline   Reply With Quote
Old 11-06-2012, 08:39 PM   #4
dem00n
dem00n's Avatar
Drives: Scion FRS
Really? I hope this doesn't become a habit, it makes me very paranoid every time i see it on...
Old 11-06-2012, 08:48 PM   #5
Jeff86
Jeff86's Avatar
Drives: 86 (FR-S)
Me too. I added a couple psi into all 4 and it went away. The cooler temps reduce your tire pressure below the threshold of the sensors.
Jeff86 is offline   Reply With Quote
Old 11-06-2012, 09:05 PM   #6
White64Goat
Rule of thumb is for every 10 degree change (colder) in outside temp. your tires lose 1 pound +/-.
Old 11-06-2012, 09:45 PM   #7
dsgerbc
Drives: BRZ(sold), STI
Pump your tires to 35 cold psi. Light comes on at around 30 (and goes off when tires warm-up from driving). If you're checking pressures indoors - add a few psi to compensate.
dsgerbc is offline   Reply With Quote
Old 11-06-2012, 09:56 PM   #8
dori.
Señor Member
dori.'s Avatar
Drives: white BRZ 6MT
Is it PMSing?
probably turned off because you drove on the tires and the turning created more heat (thus more psi) and it shut up
dori. is offline   Reply With Quote
Changed to new wheels w/o TPMS, car still thinks I have TPMS sensors? Ahz Issues | Warranty | Recalls / TSB 9 11-06-2012 08:25 AM
TPMS? 636 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 10-22-2012 10:57 AM
TPMS on the radio CMOS BRZ First-Gen (2012+) — General Topics 16 10-12-2012 03:40 PM
TPMS smbrm CANADA 2 09-21-2012 11:17 AM
so what is everyone doing about their tpms? Hachi6 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 07-22-2012 05:04 AM
