Old 12-15-2013, 03:18 PM   #1
THEmailman
Drives: Raven 6MT
Advice needed on wheel stud issue
Hello everyone, have a dilemma right now and want some educated opinions.
I track the FR-S as often as possible and did an event at the end of October at NJMP. I use dedicated track pads so I (obviously) have to take the wheels off to change them out. I did it no problem (not the first time swapping them) but since I knew I was going to be doing another event in about a month and knowing I wasn't going to be driving the car a lot in the intervening time, I opted to not swap back to stock.
Two weeks later I went in to Toyota to get the taillight (condensation) fixed and figured I'd do the 7500 mile service too. Everything went fine (as far as I knew) so fast forward to last weekend, no problems at the track. Today however I decided to swap the track pads back to stock ones. Got the fronts done with no issue but when trying to take off the passenger rear wheel, as I'm loosening one of the lugs, it feels as though I'm tightening it. Using an impact wrench yields no results either. I get confirmation on my theory from two mechanics in the shop I'm using that the lug is cross threaded.
So here's the dilemma. I did not take the wheels off since the dealership touched them so I'm 100% sure the mechanic working on it was being lazy with an impact gun and cross threaded it. But I'm sure that the dealer will deny its their fault. I always use a breaker bar/torque wrench when working on the wheels so I'm positive I did not cause the issue. I also just got moved from VA to Camp Lejeune in NC so the dealer that did the work is 5 hrs away. It seems to be an easy job so is it worth it to argue with the dealer and Toyota to admit fault and fix it for free or should I do it myself? Further, I know that I want to go to aftermarket wheels and tires in the near future, so (in the spirit of while I'm there.....) should I change to better studs and get lugs that will fit the aftermarket studs and wheels?
Thanks for reading since its a long post but you need the full background to understand the situation. Let me know your questions or clarifications.
Goodridge SS brake lines//ProjectMu 999's//Motul DOT 5.1 brake fluid//GrimmSpeed master cylinder brace//Jackson Racing Oil Cooler//Whiteline camber bolts//Raceseng CamCas plates//Kosei K4R 17x8//BFGoodrich Rivals 225/45
THEmailman is offline   Reply With Quote
Old 12-15-2013, 03:50 PM   #2
pche
Guy on internet
Drives: Slowly
I'd just change it out myself if I were you. Sounds like the dealer did it but it's gonna be hard to prove. Even if they would replace it for you it's still 5 hours away.
You don't need different studs for aftermarket wheels unless you're planning on running spacers.
pche is offline   Reply With Quote
Old 12-15-2013, 06:14 PM   #3
Tt3Sheppard
Tt3Sheppard's Avatar
Drives: Whiteout FR-S
I had the same issue and I think the dealer messed up mine as well. From what I hear the stock studs are not that strong. Since you are tracking quite often it would make sense to invest in longer and stronger aftermarket studs.
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
2003 Acura RSX Type-S
1998 Ford Escort ZX2
Tt3Sheppard is offline   Reply With Quote
Old 12-15-2013, 07:03 PM   #4
humfrz
You might consider asking the local dealer ..... they may make it right ... maybe not .... won't hurt to ask.
humfrz
Old 12-15-2013, 09:16 PM   #5
Ozzman
Drives: old
just get a new wheel stud and change it yourself, it will be the least stressful route for you to take.
Ozzman is offline   Reply With Quote
Old 12-16-2013, 08:02 PM   #6
Doborder
Godzilla Konvert
Doborder's Avatar
Drives: DMG BRZ Limited 6MT 2013
I hate to hear these stories. The OEM lugs are CRAP. I cross threaded at least 4 studs before I got smart and got new lugs. Since you track a lot, I recommend ARP studs with new lugs... You will never worry about lug nuts agains whether you use impact wrench or not. These things are almost indestructable. Also, a buddy of mine cracked all 5 studs at the track... I didn't believe it until I saw his track video and his front wheel rolled in front of him.
Its cheap insurance if you track your car often. $200 for Mutakei lugs and ARP studs
My $0.02
2013 Subaru BRZ Limited MT (DMG)
CO>CA Cartel
Doborder is offline   Reply With Quote
Old 12-16-2013, 10:54 PM   #7
Pete156
I like to eat!
He's right!
OEM lugs/studs are crap!
Pete156 is offline   Reply With Quote
Wheel stud replacement Dave-ROR DIY (Do-It-Yourself) Guides 267 01-21-2022 08:20 PM
HELP! Lug nut and wheel stud stripped! jaydee_do_work Scion FR-S / Toyota 86 GT86 General Forum 17 07-26-2015 01:50 PM
Need Advice: Broken strut mount stud... cobrabyte Suspension | Chassis | Brakes -- Sponsored by 949 Racing 27 12-22-2014 04:37 PM
Replacement Lug Stud/Wheel Hub swift996 Issues | Warranty | Recalls / TSB 3 08-30-2013 01:58 PM
Wheel stud Guaruja Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 10-11-2012 02:42 AM
