Old 12-14-2013, 09:13 PM   #1
guybaldo
Cable-tie Technician
Drives: 2013 gt86
hid bulb/ballast swap
I can't find anything on this topic sorry if it's already been covered.
Okay so I have a genuine phillips hid bulb and ballast upgrade in h11, as these are quite pricey I'm wondering if there's a way either I can get a h11 bulb to fit in the winjet headlights (h7) or is there a way to plug the h7 into the h11 ballast?
Are the ballasts specifically designed for one globe or are they universal in the bulb end? So a h7 might plug into the h11 ballast and save me changing my whole hid kit. Also do these come in bixenon or is the mechanical flap the only way?
Anyone with winjet headlights come across this problem?
Maybe just using the headlights for lows and as the drls are in the headlights doing a foglight retrofit for the highbeams as the drls are relocated?
Any help is appreciated
guybaldo is offline   Reply With Quote
Old 12-14-2013, 09:49 PM   #2
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Ballasts don't care what bulb you plug in. (Unless of course you factor in D4S bulbs)
I'm not too familiar with those Phillips ballasts but I'm assuming they use the amp connectors if you're talking about using different rebased bulbs. If so, there's no problem.
Also, "mechanical flap" is bixenon. The flap moves to expose what would be the high beam.
Old 12-14-2013, 10:00 PM   #3
infinite012
Drives: 13 DGM BRZ Ltd
Firstly, Philips (one L) does not make rebased HID kits. They only sell D1, D2, D3, or D4 bulbs and ballasts, although I'm not sure they even make the ballasts anymore.
Secondly, just find a set of H7 HID bulbs that have the same connectors as your ballasts. More than likely, like @Andrew025 said, you have ballasts that use AMP connectors, like what you see in this picture:
The other type of aftermarket bulb connector is KET, but these are rare and you generall won't come across these:
In any case, just get the bulbs and be on your way.
infinite012 is offline   Reply With Quote
Old 12-14-2013, 10:17 PM   #4
guybaldo
Drives: 2013 gt86
That's exactly what I was after, thanks so much guys. Hopefully this thread can help others with the same problem!
Old 12-16-2013, 01:30 AM   #5
ApolloSki
Stealth
ApolloSki's Avatar
Drives: Ultramarine FR-S
Has anyone tried using their H11 HID kit with the winjet headlights yet? I'm having issues with the brightness output of my HIDs, they are really dim. All I did was splice the power wires that went to the Halogen H7 bulb that came with it into my HID ballasts and plugged the bulb into the assembly.
ApolloSki is offline   Reply With Quote
Old 12-16-2013, 11:41 AM   #6
Andrew025
Andrew025's Avatar
Is it dim if the bulb is outside the housing?
Old 12-16-2013, 11:54 AM   #7
ApolloSki
Stealth
ApolloSki's Avatar
Not that I can tell. If I turn on the high beams, the light output is like how it should be on low beams and I run Xenon lights.
I ordered some H7 HID bulbs to replace the H11s Im currently using...Maybe that will help.
Old 12-16-2013, 01:39 PM   #8
Andrew025
Andrew025's Avatar
If the bulb looks like it's at full brightness outside the housing then the bulb is probably not set in the housing correctly/all the way in.
That's my guess anyway, assuming it's wired correctly.
BRZ HID Bulb Swap JPxM0Dz Cosmetic Modification (Interior/Exterior/Lighting) 19 01-24-2014 09:06 PM
taillight signal bulb non-LED swap DarkestBuddha Cosmetic Modification (Interior/Exterior/Lighting) 5 12-05-2013 11:49 PM
FR-S Headlight Bulb Swap tennisfreak Cosmetic Modification (Interior/Exterior/Lighting) 9 08-29-2013 02:48 PM
PNP HID kit with slim ballast installed. jadewbj Cosmetic Modification (Interior/Exterior/Lighting) 1 09-12-2012 11:25 AM
HID slim ballast Kit for 86 ? TRD_86 Cosmetic Modification (Interior/Exterior/Lighting) 21 08-02-2012 03:50 AM
