Old 12-13-2013, 04:47 PM   #1
Circuit Motorsports
Circuit Motorsports's Avatar
Drives: 2013 Subaru BRZ
Send a message via AIM to Circuit Motorsports
>>> Circuit Motorsports > Scion FR-S + E85 + HKS Header + EcuTek Tune!
We recently had the opportunity to tune an FR-S running E85 with an HKS EL Header.
Setup:
Stock airbox w/drop-in filter + silicone intake tube
HKS Equal Length Header
HKS Front Pipe
3” Catback
Tuned on a Mustang Dyno:
This image has been resized. Click this bar to view the full image. The original image is sized 960x720.
The FR-S ran silky smooth, pulling hard and even all the way through the rev range. Torque dip is completely gone with this header plus a tune! Peak numbers were 205whp/170wtq on a Mustang Dyno. Drivability was also excellent! We are very impressed with this combo!
Here is a comparison of E85 vs. 93 pump gas.
And a few pics of the hardware:
- Bob
Circuit Motorsports is offline   Reply With Quote
The Following 3 Users Say Thank You to Circuit Motorsports For This Useful Post:
chonody (12-13-2013), JonAvalon (12-13-2013), Victor Draken (12-13-2013)
Old 12-13-2013, 05:06 PM   #2
bfrank1972
Drives: 2013 FR-S Argento
Wow what a nice looking exhaust, and great numbers on a mustang dyno. Were those numbers scaled to 'dynojet' as we've been seeing on some other vendor comparisons? If not, do you have a general idea of scaling factor for your Mustang dyno (from experience)?
Also if you guys get a chance, video please!
bfrank1972 is offline   Reply With Quote
Old 12-13-2013, 05:41 PM   #3
Circuit Motorsports
I have a video I took on my phone I can post up tonight for you
Mustang was run with standard mustang dyno calibration, no special calibrations were applied. Mustang dynos typically read approximately 10% lower than a dynojet dyno.
-Tristan
Old 12-13-2013, 06:15 PM   #4
bfrank1972
That sounds about right - wow that's hovering around 225 'dynojet' whp (many people around here quote dynojet numbers, so I just use those for comparison). Big top end, very nice - what's the pricing on that whole exhaust setup?
The Following User Says Thank You to bfrank1972 For This Useful Post:
Circuit Motorsports (12-13-2013)
Old 12-13-2013, 06:37 PM   #5
mad_sb
Drives: 2013 Asphalt FR-S
Based on the numbers, i would say your mustang read like a dynojet. Also, from an earlier thread:
Originally Posted by Circuit Motorsports View Post
Sorry, it was a Mustang Dyno. The shop has it calibrated to read like a Dynojet, so the numbers are higher than a normal Mustang Dyno. We looked mainly at the Horsepower increase over stock, since every dyno will read differently anyway
I assume the 93 numbers were without a tune? Even with 100% stock exhaust peak power should be latter than 6250 on 93 pumpgas with a tune.
Old 12-13-2013, 08:18 PM   #6
Circuit Motorsports
@mad_sb,
We'd really appreciate it if you researched a little more before trying to discredit someone
From that same earlier thread:
We had the opportunity to dyno the BRZ we originally posted about in the beginning of this thread on a different mustang dyno at a different shop. This is the same BRZ with the same setup (drop-in filter, muffler delete), completely stock otherwise for power mods. It was verified that this mustang dynamometer was a straight up mustang with no special calibrations.
We are using a different mustang dyno at a different shop, we have been for the last couple tunes. We've verified no special calibrations are being used on this dyno. This is a standard Mustang.
I disagree with you about these numbers being dynojet numbers. Bob @Drift-Office was able to get close to 200whp on a dynojet dyno with an HKS EL header setup and 92-octane fuel. Thread here: http://www.ft86club.com/forums/showthread.php?p=1067502
It's not a stretch to imagine at least a 10% increase in whp by using E85 fuel over the 92-octane pump gas, which would put the numbers in the 215 - 220whp range easily on a dynojet dyno.
- Bob
Old 12-13-2013, 08:25 PM   #7
Circuit Motorsports
Thank you sir!
PM us about pricing
Old 12-13-2013, 09:56 PM   #8
mad_sb
@mad_sb,
- Bob
I'm not trying to discredit anyone I am just speaking from my own dyno time with my own car as well as many many hours tuning on an uncorrected dynodynamics in the past. If I didn't read correctly or understand what dyno you were using then i apologize.
The first DJ i baselined my car on it made just over 170 stock on 93 octane with the IAM at 1.0, the next one and the one i used for tuning read a good bit lower than that, fully tuned with equal length 4-1 fa20 club header (with cat), nameless catted front pipe, speedfactory single exit and E80 it made 193 in 4th... I'm sure with another hour or so on the dyno i could have found a few more hp. Also with no cats I'm sure it would have been worth a few more as well.. but 25 or 30.. nope. With no cats and another hour on the dyno I'm sure i would have been at or just over 200 whp in 4th. Hence my line of thinking that the mustang you used reads similar to the dynojet i used for tuning my car.
I'm quite familiar with the gains of E85 over pump, it's why i run E85 all the time now. What I'm not familiar with is a 93 octane tune that makes peak power at 6250. Perhaps the RPM pickup is off on that dyno, not sure, admittedly i have never used a mustang dyno. Had the power continued to climb on your 93 run the way i would expect it too, the gains you saw with E85 would look much more in line with the 15ish whp I would expect.
Old 12-13-2013, 10:12 PM   #9
Circuit Motorsports
@bfrank1972
Quick video I just threw together, not great quality but it'll give you an idea of the runs and how the car sounded.
[ame="http://www.youtube.com/watch?v=1WiEDgwoiHQ"]Circuit Motorsports - Scion FR-S Dyno runs - Tuning E85 - YouTube[/ame]
-Tristan
Old 12-14-2013, 12:38 PM   #10
Deep Six
Deep Six's Avatar
Drives: 2013 FRS / 2013 427 Vert
Last week Circuit Motorsports installed an HKS EL header and front pipe as well as 93 and E85 tunes. The results were transformational for my car this weekend at the track. I was really impressed with the amount of time committed to dial each of these tunes in. A couple hours street tuning before several hours of dyno tuning for EACH map. About 12 hours involved over 2 days. Bob is an absolute whiz at extracting optimum power while maintaining safety and drivability. This was critical for me as the car was loaded on the trailer 2 days after they finished and then pushed to the limit for 2 days at Roebling Road. Now for the results:
E85 tune on Mustang dyno made 205/170
Acceleration on the straightaway according to my Aim Solo:
Pre tune (August dry track) 105 to 120 gain 15mph
E85 tune (december damp track) 101 to 129 gain 28mph
Difference was a gain of 13 mph in just the front straight. The power is evident everywhere on the track and in damp conditions with minimal traction required careful throttle input! Still managed a 123.87 despite running 8/10 in the corners.
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor
2016 Audi TTS APR Tuned
Deep Six is offline   Reply With Quote
The Following User Says Thank You to Deep Six For This Useful Post:
Circuit Motorsports (12-14-2013)
Circuit Motorsports schtebie User/Vendor/Sponsor Reviews, Feedback, Comments 70 03-04-2014 01:59 PM
Circuit Motorsports - EcuTek Tuned Stock BRZ: 191whp / 163wtq: +17whp & +12wtq!! Circuit Motorsports Engine, Exhaust, Bolt-Ons 16 09-24-2013 12:17 PM
Borla UEL Header, works automotive parts and ecutek tune clayrush Engine, Exhaust, Transmission 14 06-27-2013 04:37 PM
Circuit Motorsports Bu-Tang User/Vendor/Sponsor Reviews, Feedback, Comments 0 05-24-2013 07:08 PM
Circuit Motorsports- Highly Recommended A+! CoRi J User/Vendor/Sponsor Reviews, Feedback, Comments 3 11-26-2012 08:30 PM
