Drives: 2013 Scion FRS
window sounds like its rubbing
Ok so its happened quite a few times now where i roll my windows down and it squeals pretty loud. I tried just cleaning the black guard piece at the bottom, sorry don't have a clue what its called. Today now I noticed a scratch about an inch and a half long vertical on my passenger window. I took it to my dealer and they said its not a warranty issue and there really is no fix for it.
Anyone have this issue or have ideas about how to rectify it? |
#2 | |
Drives: IB '05 E46 M3 ZCP
That's BS they said it's not a warranty issue and no fix. I would fight that, try speaking to a manager. It's a brand new car EVERYTHING should be covered under warranty as long as you, yourself didnt cause the problem to begin w/. |
#3 | |
Drives: Scion FR-S
If you have TechStream there is a setting in there to "automatically recalibrate" the window alignment. Didn't work for me, but might for someone else. |
Drives: Scion FR-S
I have that squeal, i just never knew what it was. and yeah, i can see the marks on the window where it glides but are only visible at night. dont know how to fix it. My FRS is 3 months old 2k miles and its making this noise from the window. Are you serious that the dealer won't fix it?!?!?!
Drives: Scion FR-S
Someone did a writeup at one point on what part of the track specifically is too tight and how to potentially DIY fix it, but I can't seem to locate it. :\ I have two separate 1.5" wide streaks up both windows. It only squeals if it's wet out, but can definitely see the lines.
Unfortunately I think this is another issue where we just have to wait. Eventually the manufacturer will be forced to acknowledge it as a problem and provide a solution. Just frustrating that all of our issues seem to be met with the "this isn't a problem" attitude for six months. |
Drives: 2013 Argento Scion FR-S
I have the same exact issue. Rubbing issues. Window makes noise. Driver side that is. My solution...silicone spray on the rubber trimming so the window can nicely slide up because it was getting caught. Quick fix until I take my car back to the dealership for more warranty issues. I've taken my car in more times into the dealership for warranty issues than I've had any of my previous 21 cars owned before. :/
Member of the year - 2016
Drives: Scion FRS
This is a problem?
Drives: on cruise control
i had that problem and recently realized that its gone. not sure how or why but it just stopped. it was my passenger window and it was really loud. i thought the window was going to shatter every time 8D
Drives: Raven Manual FRS
There were multiple threads about this problem. The felt pads on the inside of the door are coming off and scratching your window. It IS a warranty issue and has been fixed by many other dealers.
#10 |
Drives: Whiteout FR-S
Has anyone had this cause an issue with tint? I've started to notice this and am afraid that this will scratch or mess up tint in another way if i get it applied.
| How to tell if front wheel is rubbing against strut? | shu5892001 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 14 | 05-08-2013 09:54 AM |
| LIST: Non-rubbing 17" wheel & tyre packages | ft_sjo | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 04-28-2013 06:56 AM |
| Rubbing sound? | Mo707 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 01-15-2013 11:06 AM |
| Tire rubbing sound, Please Help | dco107 | Scion FR-S / Toyota 86 GT86 General Forum | 6 | 01-11-2013 10:05 AM |
| License plate rubbing on Trunk | Jayde | BRZ First-Gen (2012+) — General Topics | 28 | 08-11-2012 09:45 AM |
