| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
Drives: 2015 GT-R, 1993.5 Supra, 1995 XJR
Very nasty grinding on fast corner exit from LSD?
Hi everyone, new owner here. I am hoping for some help with a noise on my new '14 BRZ.
I'm going through break-in and first attempt after 750 miles to take a 90 degree left turn aggressively to test limits of adhesion, I hear a wicked grinding noise coming from the rear for 1/2 second from the LSD. I would be in 2nd or 3rd doing around 35mph and punching it on turn exit. Weight is loading up the right rear corner but I don't know if this is normal grinding or something wrong with fluid level or the diff is still super tight. I will be changing fluids when I tick over 1000 miles this weekend however concerned about the noise after giving the car "some stick" and aggression. The torsen in my Supra never protested this way but that could simply be it's well broken in and I never encountered it! Thanks in advance.
2015 GT-R Pearl White with Ivory, Premium | Stock, DD 1995 Jaguar XJR | Turquoise Metallic | I6 4.0L | Eaton M90, 11psi | 4L80E | 1 of 12 of 400 1993.5 Supra Turbo | Baltic Blue | 6spd | 3.77 Torsen LSD | SP57 | RPS manifold | ViPEC V88 | 525/500rwhp/tq |
Drives: 2013 Whiteout FR-S
If tc wasn't all the way off that's what you heard
Drives: Supercharged Golf Cart
Nasty sound indeed. I'm wondering if the increased forces will actually add wear to the suspension components over just letting the tires wear down from sliding without TC.
#4 | |
GBS Mafia Member
Drives: with Snow mode on
P.S. Congrats on your '14 BRZ! I see that you're from SB too
![]() GBS Mafia |
Because compromise ®
Drives: Red Herring
I am confident it is your traction control braking one wheel. Happens to me now and then on leaving t intersections and yes, the first time it happened I thought my car was imploding. As an experiment try turning your traction control off. Be ready for rear end break away
#6 | |
GBS Mafia Member
![]() GBS Mafia |
Drives: Red Herring
Go to a skid pan and have safe fun there.
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
That's just the traction control stabbing at the rear brakes. Nothing to be concerned about but you can get rid of it by turning the traction control all the way off.
As Russell Peters would say: "Be a Man! Do the right thing!" - AdrianG |
Thanks for the feedback, folks! I'll hold both buttons down for 5 seconds and then test it in a safer area.
I tried this in Sport last night and the same thing happened. I did feel the rear end shift subtly and both corners brake just as I straightened out, scrabbling for traction. Even with TC and VSC on, there's still plenty of zip and cornering capability just driving around town and feeling like taking a turn faster.
#10 |
Drives: 13 DGM BRZ Ltd
Hold down your traction control button for like 5 seconds. No need to hold the sport button as well.
#11 |
Drives: Red Herring
This.
| Tags |
| cornering, grinding, lsd, tcs, torsen |
| Grinding from 5th to 6th | tn08 | Issues | Warranty | Recalls / TSB | 3 | 08-08-2013 09:26 PM |
| corner exit traction | autobrz | BRZ First-Gen (2012+) — General Topics | 50 | 06-09-2013 01:55 AM |
| The Nasty FR-S Review Part 2 | Dezoris | Scion FR-S / Toyota 86 GT86 General Forum | 150 | 02-09-2013 10:10 PM |
| Awful grinding!!! | DatGoodBRZ | Issues | Warranty | Recalls / TSB | 13 | 11-09-2012 04:13 PM |
| Fast car Fast driver vinyl decal I need help | francosolracer | Cosmetic Modification (Interior/Exterior/Lighting) | 18 | 10-20-2012 03:43 AM |
