Old 12-03-2013, 11:15 PM   #1
ric342
FR-S driver
ric342's Avatar
Drives: ULTRAMARINE Scion FR-S
sway bars? BEST choice?
Hello fellow forum debaters, I was in the market for some sway bars and wanted some advice. What would be the best swaybar combo to buy for the FR-S? I want the best handling improvement out of this modd.
mod on
ric342 is offline   Reply With Quote
Old 12-03-2013, 11:30 PM   #2
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
None...
Sway bar barely helps. Save some money & buy other parts, like brake upgrade, suspension upgrade, tires, driving skills
Edit:
Before members go berserk over my post. What I meant was, to see full potential of sway bars, you need to know what's you're expecting, making, ideas, driving skills & goal of your 86. Without those, it's waste of money & barely helps
The Following 9 Users Say Thank You to ichitaka05 For This Useful Post:
86-tundra (12-04-2013), encity5 (12-04-2013), enjoi23 (12-04-2013), humfrz (12-04-2013), kev0 (12-30-2018), Mad1723 (12-04-2013), MaXimus (12-22-2013), Ramster (12-04-2013), stevo_12v (12-19-2013)
Old 12-03-2013, 11:38 PM   #3
whataboutbob
AutoX-10/10ths every run
Whiteline 20mm ft adj with adj endlinks, 16mm rear adj with adj endlinks. Great setup on my car.
Build thread:Here
Old 12-04-2013, 05:23 PM   #4
tr1x5tuh
The Original Super Saiyan
tr1x5tuh's Avatar
Drives: 2014 SWP BRZ
are you talking about 20mm for fronts? you are running both set ups ?
To each his own, Agree to Disagree
tr1x5tuh is offline   Reply With Quote
Old 12-04-2013, 06:01 PM   #5
1086
1086's Avatar
Drives: UM86 - 6MT
If that is the case, would the eibach pro or sportline springs (w/ stock struts) improve handling more so then? I know you can get coil overs instead, but in the spirit of staying in the same price range as sways, would those springs be noticeable/help with handling improvement ?
1086 is offline   Reply With Quote
Old 12-04-2013, 06:41 PM   #6
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Think about what you want the car to do and then look at spring rates. Better handling is different for everyone and their intention.
Do you just DD? AutoX? HPDE? Canyon runs?
What do you not like about the current handling?
humfrz (12-04-2013)
Old 12-04-2013, 06:52 PM   #7
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
I wanted to ask this question too but never did. I ended up recently buying the Eibach Front & Rear Sway bars from TireRack (they seem to have the best price shipped to CA). I'm lowered on the Pro-Kits, have upgraded to some stickier 18" tires, have a front tower strut bar, and one of my buddies told me sway bars can make a big difference. Someone can tell me I don't know what the hell I'm talking about, but my guess is that there probably isn't much difference between different brands (besides the fact that some may have more adjustment points). My goal is to just to play around with different settings. I believe that if I really tighten up the rear end, the car would oversteer more - which could be more fun and potentially more dangerous. Obviously, it won't oversteer like a Porsche 918 - RIP Paul Walker - but I want to induce a little more oversteer.
mit_peid is offline   Reply With Quote
Old 12-04-2013, 07:07 PM   #8
Sully
Drives: In the market for something fun
None...
Edit:
Truth. Unless aesthetics are your goal, don't spend $3000 on upgrading everything, use up $3000 of tires in autocross/track time. Figure out what you want.
Sully is offline   Reply With Quote
The Following 2 Users Say Thank You to Sully For This Useful Post:
Mr.Jay (12-19-2013), ZDan (12-17-2013)
Old 12-04-2013, 10:00 PM   #9
Bones36
Bones36's Avatar
Drives: 13 Brz Jrsc
I got the eibach sways. I felt a larger diffrence from sways then the springs. It's hard to describe. It turns in easier and feels flatter in turns
Bones36 is offline   Reply With Quote
The Following User Says Thank You to Bones36 For This Useful Post:
Thongpocket (12-18-2013)
Old 12-04-2013, 10:09 PM   #10
1086
1086's Avatar
Drives: UM86 - 6MT
but do Sways + springs = great?
Old 12-04-2013, 10:15 PM   #11
kendalldwhite
kendalldwhite's Avatar
Drives: Mint-Tiffany blue FRS
Hotchkiss
kendalldwhite is offline   Reply With Quote
Old 12-04-2013, 11:09 PM   #12
Bones36
Bones36's Avatar
Drives: 13 Brz Jrsc
i like it
Old 12-04-2013, 11:40 PM   #13
whataboutbob
20 f, 16 r
Build thread:Here
Old 12-05-2013, 12:49 AM   #14
Fluxx
Drives: 2013 FR-S in Ultramarine
If the sways are your first mod all they will do is make the car ride a bit harsher and make it a bit more prone to lose traction. The difference won't be world changing, but it will be there. For straight up performance and handling gains a good set of performance tires is the best bang for the buck.
Fluxx is offline   Reply With Quote
BRZ / F86 Sway bars timlewis82 Australia Classifieds 3 02-02-2014 03:06 AM
BRZ / F86 Sway bars timlewis82 AUSTRALIA 1 11-11-2013 02:53 AM
brz and fr-s sway bars different? 1010110 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 08-03-2013 01:43 AM
ST sway bars bmxhotsauce Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 05-09-2013 03:11 PM
FR-S/BRZ SWAY BARS & STRUT BARS @ NINJA AUTOSPORTS!!! NJA Brakes, Suspension, Chassis 18 04-07-2013 06:00 PM
