Old 11-21-2012, 01:49 PM   #1
slizoth
slizoth's Avatar
Drives: 2013 WRB Subaru BRZ
Disable NAV Safety Features
Hey guys,
I need to read through my manual in more depth but I wanted to know if you guys know how to turn off some of the safety features of the Infotainment system. For example I cant select a contact in my Phone menu while the car is moving but I can dial back numbers from my call log, Id like to be able to access my contacts all the time.
slizoth is offline   Reply With Quote
Old 01-20-2014, 11:30 PM   #2
nos145
Cognite
nos145's Avatar
Drives: 2013 Whiteout FRS
this feature is absolutely retarded. does anyone know how to work around this?
Thanks
nos145 is offline   Reply With Quote
Old 01-21-2014, 11:21 AM   #3
kuhlka
Drives: 2013 BRZ Limited AT
There are other threads regarding this. You have to ground a wire and splice a switch into the GPS wire. The only way you're bypassing the GPS lock-out is by making the GPS think the car is stationary -> switch.
kuhlka is offline   Reply With Quote
The Following User Says Thank You to kuhlka For This Useful Post:
nos145 (01-22-2014)
Old 01-21-2014, 12:49 PM   #4
ToyoburuBRZ
ToyoburuBRZ's Avatar
Drives: Black BRZ
Here is a way to do it without any wiring for us Canadian folk:
http://www.ft86club.com/forums/showthread.php?t=24934
Also, the reason it won't allow you to do anything is not because you are moving it is because the e-brake is not pulled. Many people have put in switches to bypass this. Just do a simple search in the DIY section
ToyoburuBRZ is offline   Reply With Quote
The Following User Says Thank You to ToyoburuBRZ For This Useful Post:
nos145 (01-22-2014)
Old 01-22-2014, 03:53 AM   #5
nos145
Cognite
nos145's Avatar
Thank you very much, I looked, but can't find relevant info.
I have one of the older head units in my FRS:
I am unable to find info for these guys, thou there's a few threads on the newer ones.
Thank you again.
Airbag disable for track / drifting? deadeyes989 Tracking / Autocross / HPDE / Drifting 10 09-02-2020 04:18 PM
How to disable DRL in FRS whitefrs Cosmetic Modification (Interior/Exterior/Lighting) 12 12-13-2016 02:11 PM
Is there a way to disable the immobilizer? schtebie Issues | Warranty | Recalls / TSB 5 09-22-2012 06:09 PM
FR-S: Highbeam turns on lowbeam, how to disable? civicdrivr Cosmetic Modification (Interior/Exterior/Lighting) 6 07-03-2012 07:08 PM
FR-S Standard Features zAnSh1n Scion FR-S / Toyota 86 GT86 General Forum 182 04-04-2012 04:23 PM
