Old 12-01-2013, 12:41 PM   #1
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
Anybody running 255/35R18 tire on +45 offset wheel in front?
I've searched haven't found anybody with the specific setup of 255/35R18 tires on 9.5 +45 offset wheels and I am concerned about the front inner clearance with the liner by the firewall or any suspension arms (not the outer fender lip/sidemarker) at full lock. I am lowered 1.4" on coilovers with -1.9 degrees of camber in front.
Old 12-01-2013, 09:00 PM   #2
switchlanez
Anyone here with that setup? Someone told me thru PM that their rear MPSS 265/35 tires on 18x9.5 +45 wheels rub a tab where the rear bumper meets the fender. I'm thinking of going same sized wheel but 255/35 MPSS. Should I expect to rub? Does lowering it too far also increase the chance of rub? I don't want to lower more than 1.4" and hope that would be enough for the tire to fully clear.
Old 12-01-2013, 09:15 PM   #3
mike the snake
My 265's just barely rubbed the rear fender tabs. With 255's I bet you won't rub at all.
The lower you go, the more camber you get on the rear. At first I had about 2" lower, then raised to 1.5" lower, and I still needed to trim the fender tabs. No big deal though, took 30 seconds with a dremel. With 255's you'll be fine I think.
In front, with 8.5" wheels, there's plenty of room at the fender. I could use a 5mm spacer to get perfectly flush.
Someone who's run the 9.5's in front will have to comment, but from what I've read, as long as you have coilovers you'll be OK.
Old 12-11-2013, 12:25 PM   #4
hanabie
hanabie's Avatar
Drives: WRB LMTD '13
do you have the diy which part of the fender tabs have to be trimmed?
Thanks
I noticed I had rubbing on 255/35 only when I'm trying to go through uneven road with a steep slope. my rear and my side rub. it depend on which side I'm travelling. It seems that my springs are not hard enough, so my suspension travels too much.
Thanks
hanabie is offline   Reply With Quote
Old 12-11-2013, 12:29 PM   #5
hanabie
hanabie's Avatar
@OP, it really depends on your road condition. I'm on ST Coils, 255/35 all around 18x9.5 +38 (7mm away from urs)
I don't think you have the chance to rub your perch. I have about 2 inches clearance from the front struts. You will only worry about your fender tabs when you lower further than 1.2".
I'm on 1.6-1.7 lowered.
Old 12-11-2013, 12:35 PM   #6
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
It should work, but you might need a 3-5mm spacer in the front so you don't rub on any end links at full lock.
I ran 17x9 et45 with 255/40/17 with KWs before I had camber plates which is pretty similar and I rubbed the wheel on the sway bar end link (strano parts FSB). But the tires rubbed on nothing though.
Now I have camber plates, adjustable sway bar end links and 5mm spacers to get the wheels out a touch.
Old 12-11-2013, 01:36 PM   #7
Anomie
Anomie's Avatar
Drives: 2014 BRZ Limited
Any idea what camber you plan on running? Most setups I've read about with 18x9.5 square and 255/35/18's end up with around -2 camber all around to make it work.
Which would most likely require the OEM camber bolt up front like you said and some lower control arms in the rear (or some whiteline camber correcting bushings but I've read LCA's are much easier to correct camber with).
Anomie is offline   Reply With Quote
Old 12-11-2013, 01:47 PM   #8
Figo
Figo's Avatar
Drives: Vortech Supercharged FR-S
+45 is not an aggressive offset. why not try smaller offset or run spacers?
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me.
Your car is your story, so don't let someone else write the book.
( White Tiger ) - FiGo's 車誌.
Figo is offline   Reply With Quote
Old 12-11-2013, 01:48 PM   #9
djdnz
1337
Drives: 2013 BRZ WRB S/C
Not so much a problem with 18" wheels though, OP is looking at 18's.
OP you will be fine, stop worrying so much :P
If you want even more proof, look for the setups that have Enkei Raijins in the front. They are 9.5" +45 and they fit with 255.
djdnz is offline   Reply With Quote
Old 12-11-2013, 02:54 PM   #10
BlaineWasHere
Grip>Drift
Drives: FRS
LOL, I didn't even think that the larger wheels would have more clearance in that way! I have yet to run an 18" set-up on my car!
But I agree with this guy, the OP will be fine. If he has any rubbing issues they will be very minor.
Old 12-11-2013, 03:58 PM   #11
hanabie
hanabie's Avatar
so r u saying minor rubbing was fine?
what kind of rubbing issues?
I rubbed my fender taps when I'm on incline/decline surfaces
Old 12-11-2013, 09:08 PM   #12
denkigrve
Random Internet dad
denkigrve's Avatar
Drives: 2013 FRS and 2010 Mini Cooper
OP you should be fine. I'm running around -2 degrees all around on 18x.9.5 +40. Tires are 255, 35, 18.
Wanna try my wheels on now that I'm running 18x9.5 +40?
denkigrve is offline   Reply With Quote
Old 12-11-2013, 10:47 PM   #13
switchlanez
Hmm, I can get -2 front camber since my coils will be slotted w/ OEM camber bolt and I believe the rear comes out to -2 natural camber if dropped around 1.25" (as I currently have with my Sportlines). I'm not that worried about the rear nor the front outer clearance (I calculated my current setup with XXR 8.75 wide +35 wheels face pokes 0.35mm further than this desired setup will). Just concerned about front inner clearance. I'm selecting a narrower tire (Hankook V12) and am pretty confident I will have no rubbing.
The wheels I really want only come in +45 and I'd like to get away with not running spacers.
Old 12-11-2013, 10:52 PM   #14
switchlanez
So I've decided on Hankook Ventus V12 tires which have a 10.2" sectional width and 8.7" tread width, narrower than most other tires in its class as well as lighter at 23 lbs. Because of its unusual narrowness, I'm so confident it'll work that I'm now toying with the idea of V12 265/35R18 tires and no fender work. Anyone try anything like that?
Will this fit? (width, offset and tire size Qs) DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4468 04-15-2024 12:31 AM
Enkei RPF1 18x9.5 5x100 38mm Offset Black Wheel - Exclusive Tony Angelo Edition Wheel Infamous Performance Wheels and Tires 122 02-13-2014 11:34 AM
Lowered 1" and have a 265/35 or 255/35 tire +38 offset please post pics! ScionFR-S Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 01-30-2014 02:26 PM
Perrin Front Front LCA Bushes Zero Offset SOLD Captain Snooze Australia Classifieds 0 05-05-2013 04:14 AM
Sport Touring class. What tire/wheel size are you running? UncleFester Tracking / Autocross / HPDE / Drifting 7 07-19-2012 03:56 PM
