Old 01-30-2014, 10:24 AM   #1
ScionFR-S
ScionFR-S's Avatar
Drives: Raven Scion FR-S
Exclamation Lowered 1" and have a 265/35 or 255/35 tire +38 offset please post pics!
If you have any pics of anyone lowered 1" or more without any camber adjustments and have a 265/35 tire in the rear with a +38 offset or close to it please post her. Just worried I may rub when I put my summer set on. Any advice is helpful
My setup:
Front: 235/40-18 +38
Rear: 265/35-18 +38 Forgestar F14s
Eibach Pro Kit Springs lowered 1" front and rear ... This is currently my clearance right now with the stock rims with a 205/50-17 general altimax winter tire
"To make it in America you need three things, a smile, a gun, and a plan. If you need to give up one thing, give up the smile. If you need to give something else up, lose the gun. But never, ever, give up your plan."
ScionFR-S is offline   Reply With Quote
Old 01-30-2014, 10:26 AM   #2
ScionFR-S
ScionFR-S's Avatar
I tried to calculate the wheel tire difference and fender gap difference from the calculator on here and it seems like my summer setup gets rid of a little more fender gap but idk if it's gunna rub... All help is appreciated
Old 01-30-2014, 11:16 AM   #3
Pete156
I like to eat!
What size rims..? Tires do not have a +35 offset, in fact they have no offset at all. Only rims do. So please tell us what size your rims are on.
This post should also be under Wheels, Tires, etc.
Pete156 is offline   Reply With Quote
Old 01-30-2014, 11:26 AM   #4
DarkestBuddha
Drives: BRZ limited GBS
+40 offset in the rear with 255/35
http://www.ft86club.com/forums/showp...9&postcount=86
DarkestBuddha is offline   Reply With Quote
Old 01-30-2014, 11:28 AM   #5
ScionFR-S
ScionFR-S's Avatar
I wasn't sure which one to post it under I will transfer it but they are 18x8.5 and 18x9.5 +38 both
Old 01-30-2014, 11:51 AM   #6
Pete156
I like to eat!
I think you'll be OK.
Old 01-30-2014, 12:07 PM   #7
ScionFR-S
ScionFR-S's Avatar
Are you running anything similar ?
Old 01-30-2014, 12:33 PM   #8
Pete156
I like to eat!
Nope. 18x8, +45 with just 225s. Lots of room
Old 01-30-2014, 01:25 PM   #9
Mach V Dan
FT86Club Official Vendor
Drives: 2013 BRZ, 2015 WRX, 2000 RSTi
There's some information in my thread about +42 18x9.5" wheels with 265/35R18 tires, over HERE.
--Dan
Mach V
Mach V Dan is offline   Reply With Quote
Old 01-30-2014, 01:46 PM   #10
ScionFR-S
ScionFR-S's Avatar
--Dan
Mach V
Lowered by how much?? And how are the rears
Old 01-30-2014, 02:11 PM   #11
Mach V Dan
1" in the rear, on Mach V springs.
Um, good. Did you actually read the thread?
--Dan
Mach V
Old 01-30-2014, 02:26 PM   #12
ScionFR-S
ScionFR-S's Avatar
--Dan
Mach V
I was driving so I couldn't read it all sorry about that and thank you for the straight answer... I'll def be okay with only 4mm out more on the rears... Fitting that in th fronts idk how you did it ahhha looks nuts
eibach, fit, lowered, rub
Request for pics of stock 215/45 tire on 8" wheel? 86-tundra Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 12-06-2013 12:41 AM
2-post lift attachments for lowered cars? DarrenDriven Northwest 0 07-29-2013 03:41 PM
WORK KIWAMI 18" x 9.5" + 18" x 8.5" +38 Offset GC GTS Aero Kit Australia Classifieds 16 03-22-2013 05:49 AM
Does anyone have pics of FR-s Lowered with stock wheels and and fatter tires?> Mrqb22 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 10-09-2012 11:24 AM
wheel offset post pics! gt86init Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 07-06-2012 05:23 PM
