Old 11-30-2013, 11:46 PM   #1
radroach
Drives: car
Driving above 6k rpm
I've been concerned about people's frying the seals off the direct injectors. I'm on a stock tune. Do I run a risk of damaging the DI seals if shift above 6k redline?
Old 12-01-2013, 12:04 AM   #2
humfrz
It's my understanding that if you don't shift really really fast.... your car will be OK.
However, please stand by for comments from people who know what their talking about ....
humfrz
Old 12-01-2013, 12:48 AM   #3
radroach
Drives: car
edit (by myself) - stand by for my comment where I don't know what I'm talking about
I was to assume that if you accidentally slip the clutch above 6k rpm that you might do damage. I love getting a chance to rev out 1-2nd gear to get good acceleration, but im not sure about the safety. Do you mean slamming the clutch into higher gears when redlining?
Concerning the nurburgring automatics which had the DI seal failures, I assume they might have run against rev limiter before shifting and causing damage.
If there's some engineering-speak I could get behind this it might turn into an actual conversation per the DO's and Don'ts of redlining; inviting input on this discussion.
Old 12-01-2013, 01:44 AM   #4
humfrz
Well, radroach, I reckon this DI seal thing is a controversial subject.
I suggest you slam this into your computers google screen and you can read up till you're as confused as I am ....
site:ft86club.com DI seals
As for me, I don't track my car ..... plus I don't feel the need to shift real fast in the higher gears, so as the rpm don't drop down below 4.500 before I give er the gas in the next gear.
Hell, I just want to enjoy my car ..... if it blows apart due to some mechanical defect ..... I'll just get another car .... I'm not married to this sucker......
humfrz
Old 12-01-2013, 02:59 AM   #5
Tagera
Drives: Hot Lava/2013 FR-S/Automatic
The boxer is a fairly beefy engine. Except for mishaps you should be fine.
Tagera is offline   Reply With Quote
Old 12-01-2013, 03:02 AM   #6
fazm
Drives: 2014 FR-S
humfrz
I'd also imagine that in retired land that another GT86 would just be noise on portfolio return.
That said, I too, plan to just drive this car as seems fit and will buy another if I need to.
fazm is offline   Reply With Quote
Old 12-01-2013, 03:20 AM   #7
Hanni_0176
Hanni_0176's Avatar
Drives: 2013 Scion FR-S 10 Series MT
From what I've read about the DI failure issue, it seems like the people who had that problem were tracking their cars. When racing on a track, you're doing more than just redlining through gears; you're keeping the rpm's high, and through certain parts of a track, likely keeping the car around 7,000 rpm's for an extended period of time before upshifting or heel-toe downshifting.
Simply redlining and then upshifting doesn't appear to be the cause. Constant on the throttle and off the throttle (throttle modulation between WOT and partial throttle) at high rpm's for extended periods of time appears to be the culprit... i.e track conditions.
Mods: K&N Air Filter - Open Flash Tablet (Stage 1 v1.55) - more to come!
Hanni_0176 is offline   Reply With Quote
Old 12-01-2013, 03:29 AM   #8
humfrz
Actually, with my retirement "income", I might have to dig out of the basement, and dust off, my old 1970 Honda Trail 90, to use ride up to the grocery store ....
humfrz
Old 12-01-2013, 03:23 PM   #9
jonbonazza
They are like an appendix. Just remove them. :P
/sarcasm
jonbonazza is offline   Reply With Quote
The Joy of Driving Be-Are-Zee BRZ First-Gen (2012+) — General Topics 17 07-21-2013 08:45 AM
Hot Key After Driving joelg Issues | Warranty | Recalls / TSB 12 07-10-2013 12:21 PM
Driving section - actually driving the things somewhere bcj Site Announcements / Questions / Issues 6 04-08-2013 11:28 AM
Driving in the wet Turdinator AUSTRALIA 47 11-28-2012 03:23 AM
Driving too much! F3dzo Scion FR-S / Toyota 86 GT86 General Forum 15 07-15-2012 01:14 AM
