Drives: Scion FR-S Whiteout
Hot Key After Driving
Has anyone noticed that their key is super hot when the pull it out of the ignition after driving? A couple times now I have just about burned my fingers on my key putting it in my pocket.
Has anyone else had this issue? |
Drives: Supercharged Golf Cart
Have your dealer change the keyfob oil, it happens from time to time.
Thanks
Key fob oil is lifetime fill...
No, I have not had anything close to that being a problem.
Drives: 2013 FR-S whiteout
Pull your codes. You probably have P8024 (fob coolant reservoir low). The reservoir is in the second trunk, adjacent to the serving trays and canoe.
Drives: asphalt FR-S
Drives: slow
Sounds like someone may have hot-wired your car at one point and left the wires exposed near the ignition lock.
You might need to run some coolant in there to cool down those hot wires. |
Drives: FR-S MT
Check for a short... and check your shorts for keyholes.
#9 | |
KCCO
Drives: 2013 Raven Scion FR-S, AT
Sent from SAMSUNG GALAXY NOTE. KEEP CALM AND CHIVE ON.
Alabama state head for Southeast 86
https://www.facebook.com/groups/Southeast86/ |
#10 |
Drives: BRZ Sport-tech
Is it AT? If yes, it's because the key connect the paddle shifters to the electronics. Completely normal.
If it's MT, the key can get got from slipping the clutch. The heat travels up the clutch master cylinder. This intense burning heat then warms up steering column and subsequently your keys. After too much clutch wear the key will stop working. It's a feature, to both burn your fingers, to let you know you're doing it wrong. And once the key stops working, the dealer can easily source the problem to your crappy shifting technique and void your warranty after you tow your car for service. |
#11 |
Just drive it
Drives: 13' FR-S
x2 on filling up key fob coolant.
#12 |
Im having a hard time separating the trolls from the helpful advice. Going to ask the dealer next time I bring it in I guess. Pretty sure Gaffigan's advice was the best I got.
#13 |
It's fine. Every car I've driven for extended amounts of time does it, Honda, Acura, Nissan, Toyota, Chevy, Ford etc. etc.
| Driving section - actually driving the things somewhere | bcj | Site Announcements / Questions / Issues | 6 | 04-08-2013 11:28 AM |
| Driving in the wet | Turdinator | AUSTRALIA | 47 | 11-28-2012 03:23 AM |
| winter driving | paraguin | BRZ First-Gen (2012+) — General Topics | 25 | 08-03-2012 05:26 PM |
| Why you are always driving uphill | FRiSson | Scion FR-S / Toyota 86 GT86 General Forum | 9 | 07-25-2012 07:37 AM |
| Driving too much! | F3dzo | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 07-15-2012 01:14 AM |
