Old 11-30-2013, 03:19 PM   #1
mike the snake
Question about oil cooler takeoff plates
I've read about many people who've installed oil coolers and reported very cool oil temps afterwards, some actually too cool IMO.
Almost all of these oil coolers have takeoff plates, with fittings and lines that go out to the oil cooler and back.
I'm wondering if one or both of those oil lines can be fitted with a valve, so that when the oil temps are running too cool, when it's cold outside or when not performance driving, I could simply close the valve/s and bypass the oil cooler?
I'm not sure how the takeoff plates work. Once installed, does the oil NEED to go through the lines to get to and through the filter, or can they be bypassed to do what I'm suggesting?
I'm hoping this could be an alternative to spending even more money on a thermostat type takeoff plate.
Old 11-30-2013, 07:20 PM   #2
mike the snake
Anyone?
Old 11-30-2013, 07:43 PM   #3
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
Get a sandwich plate with a thermostat.
Old 11-30-2013, 08:54 PM   #4
mike the snake
I have the Robispec radiator/oil cooler, which I think has a non thermostat takeoff plate.
I will have an oil temp gauge installed, and as I said I'm seeing if I can add the valve instead of buying another expensive part.
Old 12-01-2013, 04:01 AM   #5
brn12345
brn12345's Avatar
Mike, here is a link you might find useful.
http://www.pelicanparts.com/techarti...il_cooler2.htm
brn12345 is offline   Reply With Quote
Old 12-01-2013, 07:33 AM   #6
mike the snake
That link is to an external thermostat like i had on my Porsche.
I was hoping to find out about putting a valve on the oil cooler line/s on my BRZ, where the thermostat would be located in the takeoff plate.
Would the oil still be directed through the filter and engine? Or would oil flow to the engine be stopped?
Old 12-01-2013, 08:08 AM   #7
Deep Six
Deep Six's Avatar
Drives: 2013 FRS / 2013 427 Vert
I have had my Robi Cooler on for a few weeks now and I keep a scan gauge on the steering column all the time. I live in Central Florida and the weather has cooled to 70/80 for the most part. Daily oil temps run in the 170 range when cruising on freeways and 180ish in traffic. In the summer my daily temps without the cooler ran 205 to 220. At the track in August I was around 280 which prompted this decision. I will be tracking the car this weekend in Georgia where I expect 60 degree weather versus high 90 s in August.
I honestly don't know if 170 oil temps are an issue or not. My son installed a cooler on his Nismo and he went from 230 to 180. One solution could be to cap off the lines and remove the plate for daily use then reinstall for track days.
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor
2016 Audi TTS APR Tuned
Deep Six is offline   Reply With Quote
Old 12-01-2013, 11:54 AM   #8
mike the snake
Thanks for the reply.
Everything I've read about oil says that 170 is low, and the oil doesn't work properly until it reaches 200-210.
Your suggestion is one option, but if simply putting a valve inline on one of the oil lines doesn't cut the oil to the rest of the engine, I'd rather go that route.
The install and removal of the takeoff plate multiple times I'd like to avoid because I think it would increase the chances of oil leaks or failure.
Old 12-01-2013, 07:37 PM   #9
boredom.is.me
Custom User Title
Did you miss my post or something?
http://www.racerpartswholesale.com/p...andwich_Plates
Old 12-01-2013, 07:49 PM   #10
mike the snake
I didn't miss it, but you didn't include a link in your first post. That is the takeoff plate I will get if I need to, but, again, what I want to know is if I can simply install a valve on one of my oil lines to the cooler and whether or not it will work, or if it won't.
I'm seeing if I can try and save a few bucks. It's no problem to buy a thermostat takeoff plate, but if I can install an inexpensive valve and turn it on when needed, I think I'd like that option first, IF it will work.
Old 12-01-2013, 07:51 PM   #11
boredom.is.me
Custom User Title
Would the extra complexity be worth it? There would also be a higher chance of failure with more components.
You are looking for some sort of bypass. This would probably be an entire system in itself, or it would need an temp reading.
Also consider neatness.
Old 12-01-2013, 08:22 PM   #12
mike the snake
I'll simply buy the Mocal thermostat takeoff plate if my idea won't work.
Vorshlagg plates (vs) ground control thoughts and question OICU812 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 09-05-2013 02:23 AM
Technical question about oil cooler solma Engine, Exhaust, Transmission 5 05-27-2013 08:54 AM
Cheap/Crafty Oil Cooler question. Asterisked Accolade Tracking / Autocross / HPDE / Drifting 8 04-07-2013 10:45 PM
Question about adjustable LCA's vs Camber Plates vs Camber Bolts djdnz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 03-27-2013 11:38 PM
Question about Greddy oil cooler Captain Snooze Engine, Exhaust, Transmission 3 09-10-2012 03:40 AM
