Drives: Raven Scion FR-S
I want to get a tune but just have the concern of being able to flash it back to stock to bring to the dealer and not get caught. Will they be able to tell I tuned the car ?
Also when getting an emissions check and inspection will a tune not let me pass ? I live in NY
"To make it in America you need three things, a smile, a gun, and a plan. If you need to give up one thing, give up the smile. If you need to give something else up, lose the gun. But never, ever, give up your plan."
Drives: 2013 Rocketbunny GT86
There is a flash count on the ECU that te dealer can see. The only way to get around this is a piggy back system.
Most tuning solution's will allow you to flash back to a stock rom. Ecutek, OFT/Opensource, etc.
Whether or not the dealer will be able to tell is a debate that will never end across all platforms. |
Drives: Passat
Any ECU flash tune can be flashed in and out. It's as simple as flashing different firmware to your PC. The dealer won't know however I suspect that Toyota or Subaru could tell if they actually wanted to dig deep enough (Think catastrophic engine failure). Emissions testing is not a concern. All they look for are active and pending DTCs. Unichip leaves no "footprint" even for the manufacturer's but removing all traces of it for dealer visits would be a PITA and it doesn't do much anyway.
#5 | |
Drives: 2013 FRS
Shiv |
#6 | |
Subaru has similar standards. There is a counter. I wish I could provide evidence. There is a thread that talks about the counter, It might have been under an ECU TEK thread. I tried searching for it but came up empty. |
Chief
Drives: 2013 DGM BRZ Premium 6MT
Or the OP could just buy another ECU if he is that concerned about that. One ECU with the stock ROM and one ECU with whatever else.
That SHOULD work, right? |
Does anyone know the exact model of the ECU?
It should a simple matter of looking at the data sheet/user manual to determine if there is a non-volatile counter that keeps track of write cycles. It is possible to build that function into the chips, but I'd be surprised if the actual H/W has it. It's more likely what Shiv describes, i.e. they up rev the counter when a new program load is built. |
#9 | |
Drives: 2013 FR-S Argento
#10 |
I understand that and I agree I just don't want something to be prematurely worn or something go wrong with the engine or tranny and the dealer give me a big FU bc they blame it on the tune
#11 |
yes it is possible to tell if the ecu is modified. whether or not the dealers have this capability is unknown. if you modify your ecu, whether with a flash or piggyback or anything else, and it causes something to break it is not a covered repair. if something breaks unrelated to the modified piece (say your window switch quits working), it's a covered repair. you're basically concerned with how easy it will be to defraud someone.
there is a risk associated with modifying a cars ecu. it should be yours, not your dealers. if you can't afford to fix it, you can't afford to own it. |
#12 |
Drives: Passat
A spare ECU probably won't work. If you blew your engine with a flashed ECU and then installed your spare "stock ECU" for warranty repairs it would be obvious to the dealer and manufacturer because the last event recorded would be a normal engine shutdown. There may be even more telltales. It might work under certain circumstances like you know something is going wrong so you install the spare ECU weeks before going to the dealer but it's all pretty sleazy. Just accept responsibility for your actions.
| Circuit Motorsports Tuned Stock BRZ: +17whp & +12wtq | Circuit Motorsports | Software Tuning | 112 | 02-20-2014 01:13 AM |
| OpenFlash Tuning Tech: Tales from the Dyno (Stock, Ecutek and OpenFlash tunes) | Rombinhood@OpenFlash | Software Tuning | 237 | 02-10-2014 03:35 PM |
| Circuit Motorsports - EcuTek Tuned Stock BRZ: 191whp / 163wtq: +17whp & +12wtq!! | Circuit Motorsports | Engine, Exhaust, Bolt-Ons | 16 | 09-24-2013 11:17 AM |
| Got my stock BRZ tuned at Drift Office over the weekend... | edocura | Engine, Exhaust, Transmission | 46 | 05-23-2013 08:05 AM |
| 8 different GT5 Nordschleife leaderboards with the Toyota GT86 (stock, tuned, drift) | RaceR | Other Vehicles & General Automotive Discussions | 56 | 11-21-2012 09:56 PM |
