Old 11-17-2013, 06:29 PM   #1
Carolina Dyno
Carolina Dyno's Avatar
Drives: 2013
Solid Steering Rack Bushings (Press Fit)
We will be making a variety of solid bushings for our new shop car but we decided to start with the ones most directly connected to the steering feel.
We designed a solid aluminum bushing with much tighter bolt holes, and a true press fit. These can be easily installed by putting them in the freezer for 20 minutes at which point they virtually slide in.
We also took out as much material as possible bringing them from 143 grams stock to 54 grams. It doesn't sound like much but we strive to make every part as light as possible.
Carolina Dyno is offline   Reply With Quote
Old 11-17-2013, 06:35 PM   #2
Interesting. Please excuse my ignorance; what is the benefit of a lighter bushing in this location? What is the implication on durability for track applications? Am I correct in assuming that there is no downside, since the material is taken out from a non-stress point?
Old 11-17-2013, 08:36 PM   #3
Carolina Dyno
Drives: 2013
Well the stock bushing is rubber so the main advantage is the rack isn't moving without driver input. Any movement in the rubber bushings is effectively unwanted steering input.
As far as the bushing being lighter, there is no particular advantage in that location vs anywhere else on the car it's just reducing overall weight. A few grams isn't much but notice its almost 1/3rd the original weight. It might seem like such a small weight savings that it's irrelevant but if you pay attention to the weight of every detail you possibly can you can shave hundreds of pounds 1 ounce at a time.
For track durability this would be a one time purchase, you are never going to wear out a pressed in solid bushing.
Old 11-17-2013, 10:23 PM   #4
Calum
That Guy
Drives: 2013 asphalt FRS MT
How many racks have you measured to get your baseline for the inside diameter? What have you found the factory tolerance to be?
Old 11-17-2013, 10:47 PM   #5
Carolina Dyno
Drives: 2013
We've only measured two so far but we do have a couple cars coming in this week for verification. The two I measured were within 1 thou on both holes. I find this to be extremely strange considering the OEM bushing is fairly loose fitting rubber, but the odds of that being a coincidence are virtually nonexistent.
That said if anyone ever has a rack that is way off what we measured we can easily make a set to fit.
Old 11-18-2013, 02:23 AM   #6
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
hmm, nice. Any idea on price point?
Old 11-26-2013, 08:31 AM   #7
RacerDrews
Drives: 2013 WR blue BRZ
Has anything progressed with this set up yet? Would be interesting to see how much this actually is going to affect the feel of steering play if the stock bushings are as loose and poor tolerance as they claim.
RacerDrews is offline   Reply With Quote
Old 11-26-2013, 09:50 AM   #8
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
Nice!
Off topic, but I recognize your shop's name from my days in North Carolina (Went to NC State), and I believe you guys are big on the HorsepowerJunkies forum with some serious builds, including that bad ass F40 build you all did.... I was drooling over the welding work you did.
2013 SWP BRZ
Build Thread: http://www.ft86club.com/forums/showthread.php?t=38781
smbstyle is offline   Reply With Quote
Old 11-26-2013, 11:48 AM   #9
wu_dot_com
Drives: accord
what is being done to prevent corrosion? especially the dissimilar metal galvanic kind at the interface between bolt to bushing and bushing to rack?
my experience working with aircraft landing gear components made out of alum tells me that your product cannot and will not last for the life of the car as you clam due to operating environment. even with extreme protective measure, unlike rubber, or polyurethane, alum will corrode over time.
once it corrode, what is your plan to remove those bushings w/o making the hole ID oversize? putting it in is easy, removing and replaceing those bushing with basic hand tool is hard.
wu_dot_com is offline   Reply With Quote
Old 11-26-2013, 01:18 PM   #10
cmcauley
cmcauley's Avatar
Drives: 2013 Scion FR-S Asphalt 6MT
I may be incorrect on this, but I thought with aluminum parts the corrosion to aluminum oxide essentially protects the underlying aluminum. So the part itself will be okay, but this may be saying very little about it seizing against other parts that corrode.
cmcauley is offline   Reply With Quote
Old 11-26-2013, 01:56 PM   #11
wu_dot_com
Drives: accord
not really, the alum corrosion in this case propagate when it comes in contact with another dissimilar metals. so, it would continue to corrode at an increase rate even with standard anodizing protection. also aluminum oxide (anodizing) protects the wear life of the substraight aluminum by being harder, it does not do much against corrosion. also Anodizing is a special processes, its different than your natural corrosion
Old 11-28-2013, 08:05 PM   #12
Carolina Dyno
Drives: 2013
We're hoping around $40 shipped in the continental US
We have them installed on our shop car however we have a lot of things apart right now while we design a few other parts and work on our turbo setup. Even though this is a very simple part and there shouldn't be any issue with the design we wont sell something without testing it on track first. We're hoping to have it back on the road by mid December.
To be perfectly honest you're not going to see a huge night and day difference from this part alone (though it will help), like everything else chassis/suspension related it's the whole package that makes the difference.
Originally Posted by smbstyle View Post
Nice!
Thanks! That's us, here's a link to the thread for anyone interested... I know we never get sick of looking at it, definitely the most amazing street car I've had the pleasure of working on.
http://www.horsepowerjunkies.com/for...=138096&page=3
They will be available anodized for an additional fee however it's really unnecessary unless you drive you car in some really harsh conditions.
Aircraft are subject to VERY different environments, take a look in your engine bay, there are literally hundreds of bare aluminum parts connected by bolts, sleeves, bushings, etc with a variety of materials. This part is no different than those.
As for replacing it, although there is almost no chance of that being necessary in a worst case scenario any decent shop should be able to handle the job easily.
Anodizing is actually an extremely effective method of corrosion protection, however like you said purposefully anodizing a part is much different than natural oxidation.
Years ago I worked for a historic racing shop that serviced cars from road cars to race cars from the 50's and 60's. I could count on 1 hand the number of times we had issues with pressed in aluminum parts even 40+ years old.
Thanks for the interest, we will be sure to update this thread as soon as our car is back on the road.
Happy Thanksgiving!
Old 11-30-2013, 05:03 AM   #13
DriftEightSix
Pegasus White
DriftEightSix's Avatar
Drives: 86
Wow impresssive stuff on the F40!!
You looking at doing a kit for the 86?
Driving: Pegasus White Manual GTS 86.
DriftEightSix is offline   Reply With Quote
Old 12-02-2013, 10:00 PM   #14
Carolina Dyno
Drives: 2013
We just finished up our exhaust manifold flanges, and opened up a box of 321 stainless tubing. We will be creating another thread for that!
DIY: Turn In Concepts Solid Aluminum Steering Rack Bushing Install (and review) Sithspawn DIY (Do-It-Yourself) Guides 38 08-10-2018 11:07 AM
Turn in Concepts (TiC) solid aluminum steering rack bushings review CSG Mike Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 08-14-2017 08:24 PM
Steering Feel Question Concerning Tic Solid Steering Bushings brillo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 10-31-2013 04:52 PM
GROUP BUY - TiC BRZ/FR-S steering rack bushings Turn in Concepts Groupbuys 186 03-19-2013 08:04 AM
TIC Solid Steering Rack Bushing's Track Review track_warrior Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 02-17-2013 01:24 PM
