Old 11-11-2013, 02:14 PM   #1
sw20kosh
Drives: 2013 Black FR-S
Reduce under the hood temps?
Saw this post:
http://www.ft86club.com/forums/showthread.php?t=50460
Valid?
Old 11-11-2013, 02:22 PM   #2
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Are you trying to reduce intake temps or underhood temps? IMO his testing is flawed, the intake temp is mostly based on the air it's picking up and will go down with moving. If underhood temps, mount temp probes around the engine bay and do some repeatable testing.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 11-11-2013, 02:32 PM   #3
Byebye
Byebye's Avatar
I'm assuming the op's intake manifold is getting heat soaked in the thread link you posted.
You could probably achieve the same with a hood with vents. Of course that would be more expensive and won't stop rain from entering.
Byebye is offline   Reply With Quote
Old 11-12-2013, 01:19 AM   #4
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
If you are chasing lower under hood temperatures Robispec says
Originally Posted by robispec View Post
moves alot more air so I block off 3/4 of the grill both for wind resistance and front downforce
in reference to this:
sw20kosh (11-12-2013)
Old 11-13-2013, 07:50 PM   #5
icemang17
Drives: Scion FR-S/ Subaru BRZ
is your car overheating? Is heat soak effecting your supercharger?
if the answer to both is no....then WHO CARES.....sure in theory its better, but 10c (20F) drop isn't that big of a deal......
The stock cooling system in my FRS works really well, no issues even in 105F days at Thunderhill.....even with the AC on in the hotpit.....car ran perfect...
icemang17 is offline   Reply With Quote
Old 11-15-2013, 07:04 PM   #6
EN2_Squirrel
EN2_Squirrel's Avatar
I will be trying a different thermostat soon
EN2_Squirrel is offline   Reply With Quote
Old 11-15-2013, 07:21 PM   #7
CSG Mike
CSG Mike's Avatar
Originally Posted by sw20kosh View Post
Completely invalid. He's raising his temps. Remember hood cowls on muscle cars? They're there cuz they suck in air. Removing the gap behind the hood does the same thing, reducing airflow through the radiator. It only helps when you're parked.
Get a vented hood if you need to lower temps. We can help you with that. We're also testing a CSG radiator
AceHeader-MT (11-26-2013), ZionsWrath (11-16-2013)
Old 11-17-2013, 12:39 AM   #8
Captain Snooze
Drives: Red Herring
What's the deal with venting a hood then having water, dirt, bird poop flowing down the vents when parked in the rain? Is that the trade off for venting the hood?
Old 11-17-2013, 01:36 AM   #9
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
It's not ideal on a DD.
The Following User Says Thank You to BlaineWasHere For This Useful Post:
Captain Snooze (11-17-2013)
Old 11-17-2013, 03:05 PM   #10
MINOCIN
MINOCIN's Avatar
Drives: Asphalt 2013 FR-S
Since a vented hood isn't ideal for DD, I'm curious if anyone perhaps has a separate track only hood? Kind of like how many people have a separate set of track wheels & tires and track only brakes that they put on for track days. Obviously a vented hood isn't going to fit in the trunk of the car along with your spare wheels and equipment, but you could always switch out the hoods at home before leaving for the track event. That way you get you extra the cooling and downforce at the track where you need it, and the rest of the time you stick with your stock hood for DD where you get the protection from the elements.
I would think that swapping out hoods should take no longer than swapping out a set of wheels. I have a buddy who only puts on his rear spoiler for track days, which is probably no more than a dozen days out of the year.
Sure we all love our cars and look for any excuse to go canyon carving, but in our normal DD I would think that a non-vented hood would still be ok for most of us. I'm not FI and I live in beautiful Santa Barbara CA where it's never too hot or cold. So I don't know, maybe a vented hood is a necessity if you're FI and in Texas or Arizona. Here in Santa Barbara though, the weather is nice but we got a lot of trees. So there are a lot of leaves and crap flying around in the air that get stuck in the wiper area of the car. I definitely don't want that stuff getting into the engine bay. There are enough smells coming from there as it is.
MINOCIN is offline   Reply With Quote
Old 11-17-2013, 04:00 PM   #11
CSG Mike
CSG Mike's Avatar
Most authentic hoods have trays to catch things that go into the vent... although I haven't seen any authentic vented hoods for the FRS/BRZ myself yet.
Either way, it hasn't been a big deal in my experience.
Old 11-17-2013, 04:07 PM   #12
Captain Snooze
Drives: Red Herring
I must admit to being a little in lust with Robipec's vented hood
Old 11-19-2013, 07:14 PM   #13
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
@omegared19 has Prova vents installed an cut out the inside. Dropped engine bay temps significantly he said.
Old 11-26-2013, 08:19 AM   #14
AceHeader-MT
AceHeader-MT's Avatar
Drives: 2012 FR-S
Hello Mike,
Yes, it does help temp drop temps when park and sit in the pit lane.
Can you tell me how to test the "reducing airflow through the radiator."?
I would like to test it.
Thank you
Ace
AceHeader-MT is offline   Reply With Quote
Product To Reduce Dash Glare? Captain Snooze Cosmetic Modification (Interior/Exterior/Lighting) 12 08-20-2015 06:55 PM
Reduce wheel gap without lowering the car? retrosmiths Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 01-29-2014 04:34 PM
Reduce interior sound KillionsFRS Cosmetic Modification (Interior/Exterior/Lighting) 15 10-28-2013 05:23 PM
what's your solution to reduce the wheel well gap? chenshuo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 15 01-14-2013 09:25 AM
Petition to Reduce Grey Market Imports from 25 to 15 years! chulooz Other Vehicles & General Automotive Discussions 3 12-05-2011 11:59 PM
