Drives: 2013 FR-S, 2012 MCS
Greddy SP Elite cold start rattles
Anyone else with this system experience this? Is there a way to make it stop??
Drives: Silver 2013 BRZ limited
resonated front pipe, i had the same problem
I had a sp elite, paired up with headers + non resonated front pipe and it sounded bad i bought a resonated front pipe and it helped big time. |
I still have the stock catted 1 in, you really think a resonated 1 would make a big difference?
oh what.... lol nvm then
You may have some other problem going on. the stock one is catted and resonated. mine only rasped becaseu of the headers. if you have none of thta then your greddy could have a problem |
It's fuckin used...is Greddy quality something I need to worry about falling apart? Or am I just over thinking this and there is just rubbing I haven't seen yet? It looks like its in perfect shape
Drives: 2013 BRZ Limited - WRB, MT
im also running mine with stock everything else. no problems here after around 5000 miles. i'd say make sure its still tight and sitting straight
Damn. I'll have to have my local shop check it out. It's pretty bad when cold and takes about 5 mins to go away 90%. Only barely rattles when under light load after warm-up.
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
Are you sure it's not an exhaust leak?
Mine leaked with the included gasket, when cold, not matter how tight the bolts were. I ended up using two stock gaskets, with the metal lips facing outward on each.. sealed up perfectly. |
#9 | |
![]() Also how did you discover that was the problem? |
#10 |
Just drive it
Drives: 13' FR-S
isn't SP Elite just an axle back? If so, check if the exhaust is touching any other metals.
#11 |
Drives: Asphalt Scion Frs 6MT
Never had a issue with mine.
#12 |
If its an exhaust leak, you only have one joint to check since its an axle back.
Put copper silicone gasket maker in there and you are good. autozone its liek 5$ |
#13 |
#14 |
is better than you
Drives: 2013 raven FRS
| Cold start question | retrosmiths | Scion FR-S / Toyota 86 GT86 General Forum | 106 | 11-15-2016 02:14 PM |
| Cold start up popping noise | Weeber | Issues | Warranty | Recalls / TSB | 51 | 09-23-2016 12:54 PM |
| Cold weather knocking during start ups. | JDMenrique | Issues | Warranty | Recalls / TSB | 38 | 01-12-2015 11:53 PM |
| backfire at cold start | FreaQshoQ | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 10-16-2013 06:21 AM |
| White Smoke cold start up in Cold Weather (turbo cars) | whitefrs | Forced Induction | 17 | 09-25-2013 05:05 PM |
