Old 11-01-2013, 05:33 PM   #1
clintavo
Reverse lockout rattle fix
I found the source of my rattle was the plastic lockout ring loose on its nylon bushings. This method spaces the bushings more snugly against the ring.
Carefully tap out the spring pin that secures the ring. I used a small blunted nail and a sledge hammer.
Pull the nylon bushings off the shaft. Wrap above and below the slot 6-7 times with teflon tape.
Snap the bushings back on and reassemble.
My shifter is now rattle free, even winding out 3rd gear.
clintavo is offline   Reply With Quote
Old 11-01-2013, 06:44 PM   #2
Trap63
Trap63's Avatar
Drives: Brz WRB - Europe LHD
good suggest....!!! I will try to reduce or kill Kartboy rattles....tmw I will.
Trap63 is offline   Reply With Quote
Old 11-01-2013, 07:11 PM   #3
nelsmar
I really need to give this a try. Mine has gotten significantly louder every day. Its now the loudest part of my car. Thanks for the writeup!
My flickr - Canibeat
Local magazine scout
Old 02-26-2014, 12:55 AM   #4
brzadrian
I'm Batman
brzadrian's Avatar
Drives: 2013 Subaru BRZ aka Sally
anybody know where i can buy these plastic bushings..... i might have misplaced one of them...... thanks
brzadrian is offline   Reply With Quote
Old 02-26-2014, 02:05 PM   #5
HapaHaole
Drives: Grocery cart
There is a TSB for this concern.
HapaHaole is offline   Reply With Quote
Old 06-04-2014, 09:41 PM   #6
unsurety
aeiou
unsurety's Avatar
Drives: WRB BRZ
I got a Beatrush reverse lockout and it makes a muffled "snick" sound when shifting fast from 3rd-4th. Reminds me of shifting sounds in the original Fast & the Furious
Is there some way I can remedy this? I forgot to get some grease before installing it, so I just lubed the bore with residual grease from the OEM lockout. Maybe I can reach in there with something and grease it up from the bottom? Kinky, I know.
I already gouged one side of my lockout hammering that pin back in, I'd hate to try it again. Not to mention forcing that boot on again.
unsurety is offline   Reply With Quote
Old 06-05-2014, 07:01 AM   #7
JS86
I have the kartboy short shifter rattle, can anyone confirm this works>? and its removed the same way via the punch out pin ?
JS86 is offline   Reply With Quote
Old 06-05-2014, 07:56 AM   #8
Davey
Drives: BRZ Limited
Make something else louder!
Davey is offline   Reply With Quote
Old 06-05-2014, 08:35 AM   #9
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
I'll give this a try. I got the TSB done but it didn't help at all.
SloS14 is offline   Reply With Quote
Old 06-05-2014, 10:46 AM   #10
nelsmar
Lol I like my cars quiet.
Old 06-06-2014, 12:01 AM   #11
clintavo
After several months, my rattle is back, albeit to a lesser degree. I would wrap it so it is tight enough to create drag (>9 times?) on the lockout ring. As the tape compresses, it will loosen up, but hopefully prevent rattles from returning.
Old 06-06-2014, 07:52 AM   #12
Mooseknuckle44
Mooseknuckle44's Avatar
@boredom.is.me
2013 FRS-Asphalt-M6-Invidia N1, K&N drop in, plasti dipped emblems, debadged FRS, Spyder II tails, 5000K Bi-xenon HID's, red demon eyes, Quad halo's, switchbacks w/Tapturn mod,Grimmspeed hood struts, led everything exterior, H&R 25mmF/15mmR spacers, Sportlines, SPC LCA's..(FUN car)
Mooseknuckle44 is offline   Reply With Quote
Old 06-15-2014, 04:36 AM   #13
unsurety
aeiou
unsurety's Avatar
Drives: WRB BRZ
Thanks @clintavo. Did this for my Beatrush lockout, which was a tiny bit loose, and made some noise when shifting.
I did this fix tonight and it works great. In addition to the teflon tape, I got a small tube of white lithium grease and put a light, uniform coating all over the shift lever (and the area between the teflon tape), the flared base, and the bore of the lockout. A small amount around the nylon bushings for good measure too. My lockout is much tighter and quieter now. Hope it stays this way.
Old 10-11-2017, 08:25 PM   #14
fanuel fierros
Drives: 2013 scion frs
i wish i could see the pictures lol
Sent from my SAMSUNG-SM-G890A using Tapatalk
fanuel fierros is offline   Reply With Quote
Beatrush Reverse Lockout Lever simpleisbest Cosmetic Modification (Interior/Exterior/Lighting) 37 04-16-2015 10:19 PM
Shift Knobs and our Reverse Lockout Chewie4299 Cosmetic Modification (Interior/Exterior/Lighting) 19 07-28-2013 12:23 PM
FR_S/BRZ Reverse Lockout Lever brzadrian BRZ First-Gen (2012+) — General Topics 20 06-20-2013 04:07 PM
Reverse lockout vibration SubaSteve Issues | Warranty | Recalls / TSB 4 03-23-2013 01:26 PM
Aftermarket Reverse Lockout Ring Available? was385 Cosmetic Modification (Interior/Exterior/Lighting) 9 02-17-2013 02:28 PM
