Hotchkis Spring Install
Long story short: I have the Hotchkis TVS Stage 1 Suspension upgrade for my BRZ and I decided to install it the other night. I have everything except for a spring compressor, but I work at a Toyota dealer so I just brought the assemblies into do the spring swap. I tossed them in the back of my truck not thinking anything of it, but when I got home, I noticed that the logos were upside down on the front strut assemblies, and the tighter wound coils are on the bottom. Is it possible that the logos were just put on upside down, or are the entire springs upside down? I spoke to the tech that installed them and he said that they were installed correctly based on which side fit into the top hats.
Any insight? I'll post pics later when I'm home if it's a big deal thanks |
Did you think to go to the DIY section????? Hmmm? http://www.ft86club.com/forums/showthread.php?t=10842
This may provide you with some clues.............. |
Nope I didn't think to
Anyways, my memory must be failing because upon further inspection, it was the rears that were upside down and they have symmetrical ends so I'll have them swapped over. Problem solved, sorry for the hassle |
Drives: 2013 FR-S, 2012 MCS
Post pics anyway please
For sure.
This is the spring installed correctly, with the tightly coiled progressive side up. The rear spring has a similar top and bottom end, so i can see how the mistake was made by the guy who swapped mine over ![]() Sent from my HTC One using Tapatalk
| Places for spring install in RVA? | mbh1101 | Mid-Atlantic | 3 | 09-14-2013 02:45 PM |
| Spring Install LCA To Hub Question | FRS1010 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 08-14-2013 06:17 AM |
| Spring install | DaBrz | Northwest | 8 | 05-14-2013 10:47 AM |
| East bay shops for spring install? | WillBRZ | Northern California | 9 | 02-21-2013 02:03 AM |
| vibration after spring install? | sajonf | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 08-30-2012 02:30 PM |
