Old 10-29-2013, 10:07 PM   #1
Garstang
Garstang's Avatar
Drives: FRS
Sub woofer setting.
I have the touch screen stereo. Can some one please tell me what the phase is for. You can take the phase in to the positive numbers or negative numbers. What doe the normal or reverse setting do as well for the sub?
Garstang is offline   Reply With Quote
Old 10-29-2013, 10:46 PM   #2
buzznasa
LOL PWR
buzznasa's Avatar
Drives: Whiteout FR-S; Scion tC
The phase setting determines if the driver (the cone itself) will push or pull on a given input. This can have an effect depending on the order of enclosure (2nd order, 3rd order, 4th, 5th, and so on) by decreasing the deformation of the driver on a bass hit. Sub-woofers are meant to push outward and thus will deform less than when they are pulled inwards which means a cleaner and tighter bass hit.
I am running a 4th order (ported) tube sub wire in bridged mode from the amp. I got a noticeable increase in sound pressure when I reversed the sub input.
Some of the folks that were at the 86 Fiesta last week stuck their heads in my car with the volume up half-way up. I think they liked the sound
It's not a midlife crisis if you never grow up.
buzznasa is offline   Reply With Quote
Old 10-29-2013, 11:05 PM   #3
Garstang
Garstang's Avatar
Drives: FRS
A few questions
Okay so I want to put by setting on reverse. Is that correct. Not understanding the order thou. What are you referring to ?
Old 10-30-2013, 05:06 PM   #4
buzznasa
LOL PWR
buzznasa's Avatar
Sorry for the confusion. The order refers to the sub woofer enclosure. If you don't have a subwoofer (it would have to be a dealer add on or you would have to install it yourself) then the reverse does nothing for you. It just reverses the polarity of the signal going to the amp. Just like flipping a battery around backwards.
You can find the install that I did in this thread.
Old 10-30-2013, 05:35 PM   #5
IceFyre13th
IceFyre13th's Avatar
Drives: Mazdarati
:l aughabove:
I have not heard something that funny in a long time, lots of big words and catch phrases that put together as above mean absolutely nothing.......but hey, you sound like you stayed at the Holiday inn.
REAL ANSWER-----> http://www.energy-speakers.com/suppo...phase-details/
BOX Types-----> http://www.the12volt.com/caraudio/boxes6.asp
IceFyre13th is offline   Reply With Quote
DIY Sub-woofer Installation chris's fr-s DIY (Do-It-Yourself) Guides 14 10-18-2016 09:13 PM
woofer option that wont take space in trunk wrb Electronics | Audio | NAV | Infotainment 6 07-23-2013 09:09 AM
TC and VSC mode setting ShowTime_DW Scion FR-S / Toyota 86 GT86 General Forum 12 05-28-2013 06:55 PM
What is a good setting to put for the rev myjobis2pimp NY / NJ / CT / PA 22 04-25-2013 05:58 PM
This is how I pan on setting my car up where does it put me jdzumwalt Tracking / Autocross / HPDE / Drifting 16 02-10-2013 10:24 PM
