Old 10-27-2013, 01:17 AM   #1
diss7
Drives: AE86, 2x GT86, TE27
When lowering 2 inches or more...
I see more people lowering their cars 2 inches and beyond, and an wondering what other components are going to need to be replaced to get a decent alignment?
At that height, rear camber will be fairly extreme, so will need rear LCA to pull that back. I also imagine the stock toe arm won't have that much adjustment, so will need to replace that.
At the front, camber won't be affected, so am thinking the whiteline balljoint/tie rod end is a quick fix; however would you be better to go front lca?
Interested to hear what those at this height have done.
Thanks
diss7 is offline   Reply With Quote
Old 10-28-2013, 07:51 AM   #2
Anthony
Weight Nazi
Anthony's Avatar
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
Interested in this as well.
Build Thread | The Venus Project | Any car which holds together for a whole race is too heavy.
Anthony is offline   Reply With Quote
Old 10-28-2013, 09:24 AM   #3
TOZER
Drives: 2013 Whiteout FR-S
Sub'd
TOZER is offline   Reply With Quote
Old 10-28-2013, 09:27 AM   #4
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
I'm lowered 4.5" and after adding lca's my toe maxed out. I only have -4 in the rear and already have my toe off.
Old 10-28-2013, 09:31 AM   #5
Anthony
Weight Nazi
Anthony's Avatar
Originally Posted by SmsAlSuwaidi View Post
I'm lowered 4.5"...
You driving a car or a submarine?
The Following 5 Users Say Thank You to Anthony For This Useful Post:
mwjcyber (10-28-2013), Starkiller (10-28-2013), Stealth Gt86 (10-28-2013), Stierzy34 (10-28-2013), SubiePig (10-28-2013)
Old 10-28-2013, 09:38 AM   #6
SmsAlSuwaidi
Boosted
A torpedo
The Following User Says Thank You to SmsAlSuwaidi For This Useful Post:
Anthony (10-28-2013)
Old 10-28-2013, 10:18 AM   #7
mwjcyber
mwjcyber's Avatar
Drives: 13' Subaru BRZ Limited SWP 6MT
When dropped 2", you're new camber will be approx -1deg front, -2 deg rear.
Front: coilover camber plates give you +/-2deg camber adjustability, crash bolts ~1deg, and stock toe adjustment can handle this drop without mod.
Rear: stock toe adjustment, but no stock or coilover camber adjustment, so you'll need bushings or LCAs. The SPC LCAs come with rear toe bushings, but you shouldn't need them for 2" or less drop.
FYI, I recommend LCAs over bushings, because if you include cost of a shop using a press to swap bushings, it costs the same as some LCAs; which you can install yourself and easily swap back to stock.
Great video detailing rear LCA installation and alignment.
[ame]http://youtu.be/pQ5fCjMIfjI[/ame]
mwjcyber is offline   Reply With Quote
The Following User Says Thank You to mwjcyber For This Useful Post:
diss7 (11-11-2013)
Old 10-28-2013, 10:55 AM   #8
Anthony
Weight Nazi
Anthony's Avatar
A torpedo
YES!
Wheel Directory: Racing Hart CP-035 17x7.5 +48 quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 02-17-2016 11:28 AM
Lower car 1.5 - 2.0 inches F3dzo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 06-23-2012 09:30 PM
