Old 10-26-2013, 07:35 PM   #1
FRSFirestorm
Red is Fastest
FRSFirestorm's Avatar
Drives: 13 FRS 6MT Firestorm
Wheel Hop
I've put the winter stock tires/wheels back on. Decided to go out and practice launching. Any wheel spin resulted in some pretty serious wheel hop.
I'm wondering if this is a result of the Eibach springs and Koni's. I put them to full soft and it still did it.
Wondering if stock suspension guys are seeing wheel hop?
FRSFirestorm is offline   Reply With Quote
Old 10-26-2013, 08:07 PM   #2
Kostamojen
Drives: 1993 Impreza w/ WRX Swap + FWD!
Was you traction control off?
Kostamojen is offline   Reply With Quote
Old 10-27-2013, 07:54 AM   #3
Calum
That Guy
Drives: 2013 asphalt FRS MT
Wheel hop would be pretty hard to search for because the search engine ignors anything with three characters or less, so here.
http://www.ft86club.com/forums/showthread.php?t=29020
What tire pressure are you running in the winter setup? I find with 32 psi in the stock tires, running RCE yellows, I get wheel hop fairly easy. At 36 psi it's all but gone.
Old 10-27-2013, 09:14 AM   #4
FRSFirestorm
Red is Fastest
Yes, traction control off.
Tire pressure is @ 36psi. Should I get serious, say take it to the 1/4 mi track, I'd play with the pressures. Thanks for the link. I'll give it a read.
Old 10-27-2013, 09:42 AM   #5
Mikem53
Drives: FR-S 6MT
The IRS setup is not ideal for hard launches and will cause wheel hop. I haven't tried launching mine hard to see in this car yet. Had this problem with my corvettes.. Nothing like a camaro or mustang with a solid axle for those hard launches..
Mikem53 is offline   Reply With Quote
Old 10-27-2013, 11:58 AM   #6
Calum
That Guy
As was mentioned in the link, wheel hop is caused by the suspension absorbing energy, winding up until something binds, and releasing that energy. It could easily be the tire sidewalls that are flexing and unflexing so to speak. That my conclusion from my own tire pressure testing with this car.
Old 10-27-2013, 12:11 PM   #7
Suberman
Drives: Subaru BRZ Sport Tech Satin White
Full soft is too soft in rebound. That's why you're getting wheel hop. Why did you do that? Unless you can adjust jounce, not usually, changing rebound is silly. There will be an ideal range, very narrow, for rebound setting as this is needed for wheel control. Setting rebound too soft is as bad as setting it too hard. For hard launches you need higher rebound resistance, not lower. You generally set rebound as soft as you can and still maintain wheel contact in bumpy corners, for wet or winter driving. For dry track work you can increase rebound resistance a click at a time until you get no improvement in lap times, highly dependent on track surface and the type of bumps.
IRS is normally pretty much immune to wheel hop. The poster who thinks live axles are better doesn't understand how suspension works.
Leaf springs are worst because the axle actually winds up against the springs and them let's go, traction bars were invented for this reason. More "modern" live axles such as fitted to the new Mustang use multi link design with coil springs partly because live axles are so awful to drive otherwise. The new Mustang doesn't suffer from wheel hop (tramp) due to this sophisticated set up, irony is irs would have been cheaper probably!
Suberman is offline   Reply With Quote
Old 10-27-2013, 02:42 PM   #8
FRSFirestorm
Red is Fastest
Thanks for the input. I've had rebound mid setting, I took them to full soft as I've taken a new job and traveling quite a bit on rough roads, not as a test for the hop. It hops at mid and soft setting. I'll try firmer settings sometime.
WTB: Stock steering wheel (wheel not airbag) mobybrz Interior Parts (Incl. Lighting) 2 09-11-2014 02:23 PM
Enkei RPF1 18x9.5 5x100 38mm Offset Black Wheel - Exclusive Tony Angelo Edition Wheel Infamous Performance Wheels and Tires 122 02-13-2014 11:34 AM
Wheel Directory: ProDrive GC-012L 18x8.5 +48 MarkMash Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 20 05-12-2013 03:55 PM
OK wheel gurus, wheel are here, now for tires FRSGT86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 02-12-2013 01:36 AM
Are there any RWYB Wheel to Wheel road races? LexusFman Other Vehicles & General Automotive Discussions 1 11-05-2011 12:28 PM
