Old 02-14-2013, 08:44 PM   #1
Simmons
Simmons's Avatar
Drives: 2024 GR86/ 2015 FRS
How to fix wheel Hop
What causes wheel hop on these cars, is there a way to fix it?
Thanks,
Simmons
2024 GR86 71 STR/ 2015 FRS 71 STX
Sponsors Xero-Limit//Karcepts
Simmons is offline   Reply With Quote
Old 02-14-2013, 08:50 PM   #2
husker741
Burnouts.
husker741 is offline   Reply With Quote
The Following 8 Users Say Thank You to husker741 For This Useful Post:
8R6 (04-23-2014), charged86 (08-23-2013), civicdrivr (04-24-2013), Dimman (04-06-2013), EsoBOFH (04-15-2016), ftc~brz (09-24-2013), QuikSilveRX-8 (04-24-2013), Turdinator (04-24-2013)
Old 02-14-2013, 08:56 PM   #3
Walldodger
Walldodger's Avatar
Drives: Four wheels, two seats, etc
Do you mean the wheels are tramping on acceleration? I didn't think that was a problem with these cars.
But first I've heard of it.
Walldodger is offline   Reply With Quote
Old 02-14-2013, 09:54 PM   #4
dorifuto
If in doubt,flat out
dorifuto's Avatar
Drives: 2013 brz
I've dumped the clutch and smoked the tires plenty of times. Never once had wheel hop.
dorifuto is offline   Reply With Quote
Old 02-14-2013, 10:28 PM   #5
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
I get wheel hop all the time. Just not when sideways. It happens more on damp roads. And it is violent.
Needs subframe bushings I think.
Coheed is offline   Reply With Quote
Old 02-14-2013, 10:38 PM   #6
Simmons
Simmons's Avatar
Nope, I already have them and it didn't help.
Simmons
Old 02-14-2013, 10:46 PM   #7
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
Control Arms
Tansey86 is offline   Reply With Quote
Old 02-14-2013, 11:56 PM   #8
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Differential bushings maybe? There are some trailing arm bushings and stuff available too but this is the first i've heard of this issue.
JoeBoxer is offline   Reply With Quote
Old 02-15-2013, 07:36 AM   #9
NYC BRZ
AutoX Addict
NYC BRZ's Avatar
Drives: 08 Pontiac G8 GT,13 GBS BRZ Limited
Control arms, controls arm bushings, and diff bushings. It worked for my G8 GT.
Sent from my Galaxy S3 using Tapatalk 2
2013 BRZ Limited- GBS - 6MT -VIN #0937
~~NYR SCCA # 18 C Street R (CSR)~~
"But there’s no mistaking the noise. This car is loud, and not in a particularly nice way. There’s no crisp exhaust note, no induction wheezing. It’s just the sound of petrol exploding in a metal box." - Jeremy Clarkson
NYC BRZ is offline   Reply With Quote
Old 02-15-2013, 07:52 AM   #10
Calum
That Guy
Drives: 2013 asphalt FRS MT
[ame="https://www.youtube.com/watch?v=IDfJ_zYFPcs"]BRZ / FT86 / FR-S Whiteline Subframe Lock Out Kit - YouTube[/ame]
Watch the diff bushings in this video.
Wheel hop can come from a lot of places, if you're getting it you need to take care of all of them. I think those stock diff bushings are going to be one of the weakest links. But subframe bushings, control arm bushings, springs and shocks, and even the tires can all play a part. I know guys that would swap strut/springs packages if they were going from drag radials to slicks.
This can get as in depth as tuning the rest of the suspension.
For now, try adding 2 more psi to your tires and see if that helps.
The Following User Says Thank You to Calum For This Useful Post:
continuecrushing (04-24-2013)
Old 02-15-2013, 11:54 AM   #11
wparsons
wparsons's Avatar
Will diff bushings actually do anything for wheel hop? I would think only parts that actually effect the suspension (subframe and control arm) bushings would have an effect?
flickr
Old 02-15-2013, 12:40 PM   #12
xxscaxx
Drives: 2013 SWP BRZ
I get this a lot on my winter tires... If I step on it and i'm on a crappy road, my TSC goes off and you can just see my RPM's bouncing. its annoying as shit. I never noticed it with my stock tires. I just assumed it was the snows.
xxscaxx is offline   Reply With Quote
Old 02-15-2013, 01:30 PM   #13
Noob4Life
86 Noob
Drives: Firestorm FR-S
I replaced just the dogbone mount in my jetta with a stage 1 poly mount and there was so much less wheel hop that I actually thought id lost some power. The difference was might and day.
Sent from my SAMSUNG-SGH-I317 using Tapatalk 2
Noob4Life is offline   Reply With Quote
The Following User Says Thank You to Noob4Life For This Useful Post:
jeepmor (04-28-2022)
Old 02-15-2013, 01:39 PM   #14
A5D5TRYR
A5D5TRYR's Avatar
Drives: FR-S 6MT Ultramarine (BeeDrill)
I seem to get this with my winter tires as well.
2013 Scion FR-S - Ultramarine 6MT
A5D5TRYR is offline   Reply With Quote
Wheel Directory: ProDrive GC-012L 18x8.5 +48 MarkMash Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 20 05-12-2013 04:55 PM
OK wheel gurus, wheel are here, now for tires FRSGT86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 02-12-2013 02:36 AM
Wheel Gap & Wheel Size white_knight Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 01-26-2013 11:01 AM
Are there any RWYB Wheel to Wheel road races? LexusFman Other Vehicles & General Automotive Discussions 1 11-05-2011 01:28 PM
