| DIY (Do-It-Yourself) Guides For all DIYs. |
Drives: Subaru BRZ
Auto Windows roll up when lock the car
Hello
I want to install Auto Windows roll up module, so that the car will roll up winnows automatically when i lock it . I got the module on order http://www.ebay.com/itm/140410237014...84.m1439.l2649 Now all I need is to know where are the DIRECT wires that connect to the motors of the windows, I couldn't find it in the BRZ electrical diagram ,Can some one help ?
Drives: SWP BRZ
hmmm interesting..since it's very cheap i would like to know too
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
It looks like everything you're after is in the web interface of the shop manual.
Here's what you need: http://www.ft86club.com/forums/showthread.php?t=35279 |
Drives: Subaru BRZ
Thanks I will look in to it today, hopefully will make it work,
Drives: white Sport-tech
#6 | |
Drives: Brz WRB - Europe LHD
I don't understand where to wire in a standard wiring system without alarm box.
Drives: Subaru BRZ
for Me I installed Remote Start/ Alarm system so I have this dedicated wire for roll windows Up, connected today the module (for windows) for Driver side
but it doesn't work, when i lock the car the window jumps half an inch and stops, and that's it. ![]() in the picture is where i connected the roll up module |
Sorry for enclosed pic in italian...but I installed some modules in some cars and all are fitting in the same way (electrical). One wire even to Ground, one to 12+ battery and one pair per side window (LH and RH).
The command wire is coming from alarm and it seems to be in operating status as the "antenna amplifier input 12+". In this example the command wire from alarm (AUX exit) is "rosa", PINK. Another feature to identify is if BRZ wiring window hub on UP with "+" polarity or not. Maybe the "consensus wire" could be wired to "schema/section" where system close up doors with remote/keyless input
#10 | |
I Love custom Turbo kits
Drives: Limited BRZ
Please read this thread. Especially the last two posts. CAUTION!! http://www.ft86club.com/forums/showt...152#post921152
#11 | |
Adapting this subaru OEM kit may work for the window roll up function. Unfortunately I do not have the part number so probably need a vendor to source one from Japan.
#12 | |
#13 | |
The added subaru OEM auto folding kit came from an aussie shop called garge88, unfortunately they purposely pulled the part number sticker off so I wasn't able to get the part number. It is definitely a jap kit as the instructions were in jap so no it is not through techstream. It only had a plice into the doorlock connector and the other connectors were pretty much like a piggy back system off the stock power window switches. |
#14 |
Maybe this one?
http://www.aichi-toyota.jp/shop/prod...product_id=851
| Auto Lock (Doors) | pinoyplaya | BRZ First-Gen (2012+) — General Topics | 67 | 11-13-2017 10:47 AM |
| Windows dont auto anymore | _F-R-S_ | Issues | Warranty | Recalls / TSB | 23 | 02-06-2014 10:41 AM |
| Auto Lock and Convenient Unlock | delusional | DIY (Do-It-Yourself) Guides | 4 | 11-07-2012 05:34 PM |
| Nagisa Auto D-Lock Super Low Seat Rail | poormans_LFA | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 11-06-2012 04:35 PM |
| Auto-lock locking me out of car! | Bobasaur | BRZ First-Gen (2012+) — General Topics | 15 | 07-06-2012 04:37 PM |
